Hi Bill,
I wasn't aware that any version of the Spitfire engine had a fan
clutch. A fan clutch, that would fit correctly in the existing
shroud, would certainly be the simplest was to get some noise
reduction. Let me know what happens with your tests. Perhaps you
could send me a couple of photos too. That might help me figure out
some fix for any problems that might occur.
--- In amphicar-lovers@y..., "Bill Norris" <wnorris@m...> wrote:
> Professor Friese,
> What would you think about a simple small fan clutch to simplify the
fan
> noise and cut HP loss at highway speed but not when engine needed
more
> cooling? This is what I'm in the process of testing. I've tried the
electric
> fans and that requires serious modicacations.
> I'll let you know what happens after this weekend. I've installed
all extra
> updates, alt, RPM, water detector, and also in process of having
FM99691UE
> engine built up for my red 67. That is 79 Spitfire, with a fan
clutch on
> water pump.
> Give me your thoughts
> Bill Norris
> ----- Original Message -----
> From: "jfriese" <jfriese@m...>
> To: <amphicar-lovers@y...>
> Sent: Tuesday, August 20, 2002 1:07 PM
> Subject: [amphicar-lovers] Re: Fan noise
> > Hi Tommy,
> > There is no hose fitting on the flame arrestor. On cars with a
sealed
> > oil cap, the hose goes from the rocker arm cover to the air
cleaner,
> > outside of the filter material.
> > John Friese
> > 67 White
> > 67 Red
> > --- In amphicar-lovers@y..., tommyintpa@a... wrote:
> > > In a message dated 8/19/02 11:59:00 AM Pacific Daylight Time,
> > > minnow@a... writes:
> > > Hi all, About that air cleaner is it for an Amphicar? What is
the
> > hose for? I
> > > thought if you use a flame arrester you used a non-vented oil
fill
> > cap and
> > > the rocker arm cover has a hose that connects to the flame
arrester.
> > Or like
> > > the early cars that use a vented oil fill cap, no hose at all
from
> > the top of
> > > the rocker arm cover and on flame arrester. Neither type uses a
hose
> > from the
> > > air filter to anything. Just wondering?
> > > Tommy in Tampa
> > > [Non-text portions of this message have been removed]
> > THE AMPHICAR-LOVERS LIST
> > Before posting requests for information, please check the List
> > Archives:
> > For more information about this List and other available services
> > visit:
> > To UNsubscribe from this List, just send a blank email to:
> > amphicar-lovers-unsubscribe@y...
> > Any other issues may be addressed to the List owner (Mike Israel)
at:
> > amphicar770@y...
> > Your use of Yahoo! Groups is subject to
