Exhaust System Replacement
RalphF
I know I posted this in Facebook but wanted to have it in these archives for anyone searching the topic. I had a lot of great advice from Cap'n John Bevins!
I guess perhaps he couldn't find the right muffler, so PO had cut the old J Pipe off to within about 1-2 inches of the manifold and put a flexible pipe there along with some weird tractor-looking muffler. The flex pipe broke so I repaired it with a soda can temporarily.
Later, I replaced my J pipe and muffler. I went ahead and removed the carb and manifold because I was wary of possibly stripping something I couldn't see. It wasn't that bad of a job. Luckily the PO had given me a spare manifold gasket.
Looks like Gordon's doesn't currently list the muffler, plus when they did it came with the tailpipe. I had just bought a pipe one 2 months prior when they were on sale so I didn't need another and they wouldn't sell it without it.
So I have an alternate source and part number for the muffler. You still have to weld on a small angle bracket just like the Gordon one. The replacement muffler I used was sort of rare: 1979 VW Super Beetle, California only. It was made in Denmark. https://www.ebay.com/itm/363010414214 They did raise the price $20.00 after I got it.
B Exhaust J pipe replacement General Amphicar Discussion 3
Ed Price Exhaust Question General Amphicar Discussion 10
D Exhaust order General Amphicar Discussion 5
L Exhaust General Amphicar Discussion 7
D Stainless steel exhaust General Amphicar Discussion 3
G Exhaust Flange General Amphicar Discussion 0
A Exhaust manifolds General Amphicar Discussion 0
L Amphi Exhaust Manifold Needed General Amphicar Discussion 0
A Exhaust manifold and SU carrbs General Amphicar Discussion 3
E Unleaded Gas & Exhaust Valves General Amphicar Discussion 0
M Gasoline, exhaust or bilge aroma? General Amphicar Discussion 2
D Exhaust Seal General Amphicar Discussion 0
B Exhaust Studs General Amphicar Discussion 5
Propcar50 Ignition System Does Not Energize General Amphicar Discussion 1
B Charging system General Amphicar Discussion 11
dutchamphi Draining Cooling System General Amphicar Discussion 2
T Interesting Filter for Amphicar cooling system General Amphicar Discussion 0
I Throttle Body Fuel Injection System General Amphicar Discussion 4
M CounterAct anti-rust system General Amphicar Discussion 1
G cooling system General Amphicar Discussion 1
A BRAKE SYSTEM HELP!!!! General Amphicar Discussion 4
K charging system General Amphicar Discussion 2
R system check General Amphicar Discussion 2
S Fwd: Fw: EMERGENCY FRIENDS SYSTEM General Amphicar Discussion 0
W VEHICLE STORAGE SYSTEM General Amphicar Discussion 0
A less expensive replacement for axel slip joint General Amphicar Discussion 2
LSolheim Replacement Coil? General Amphicar Discussion 26
S Replacement License Plate Bulb General Amphicar Discussion 1
S Speedometer Cable Replacement General Amphicar Discussion 4
D Vent Glass Replacement General Amphicar Discussion 1
A NEW REPLACEMENT GLOVE BOXES ARE NOW ON EBAY General Amphicar Discussion 1
W seal replacement General Amphicar Discussion 1
G U Joint Replacement General Amphicar Discussion 4
S Replacement Parts General Amphicar Discussion 0
L fuel pump replacement General Amphicar Discussion 2
T fule pump replacement number General Amphicar Discussion 2
A Replacement Sun Visor General Amphicar Discussion 0
T Replacement sun visors General Amphicar Discussion 3
E Replacement Front Shock Source General Amphicar Discussion 0
B Amphicar Universal/Replacement Parts Tips General Amphicar Discussion 0
S Questions about oil change and replacement upholstry... General Amphicar Discussion 2
