Engine front plate
I made up these engine plates for the Amphicar. The front motor mount bolts to it. They are different than the Triumph 1300 and 1500 motors but with this plate you can install them in a Amphicar. They will come with the lower bracket(black in pic) the cost is $85.00 pl shipping. I will be driving down to Fl. , the end of October.
part # 759/1800 pic # 02-24
SNOWBIRD Engine surprise General Amphicar Discussion 1
D Engine Draft Tube General Amphicar Discussion 3
Jon March Proper engine break-in General Amphicar Discussion 4
mike_israel 2-ton engine hoist for $143 General Amphicar Discussion 0
Jon March Engine compartment - !@# manual scraping. stripping, degreasing, sanding, priming, painting General Amphicar Discussion 6
P cautionary tale (my engine upgrade experience) General Amphicar Discussion 14
okey0 Engine OUT....how to mount on stand now? General Amphicar Discussion 9
Akamphi Engine oil priming tool General Amphicar Discussion 3
Ken Chambers Entertaining engine rebuild General Amphicar Discussion 0
Akamphi Spit 1500 engine break in. General Amphicar Discussion 1
AHite Possible Engine Conversion General Amphicar Discussion 8
S Pulling an engine General Amphicar Discussion 7
A engine timing and dwell General Amphicar Discussion 3
Midwest Amphicar Engines engines who needs an engine General Amphicar Discussion 4
azpaul50 Engine Cover Luggage rack General Amphicar Discussion 6
Midwest Amphicar Engine cover holes or how I spent today General Amphicar Discussion 1
B Re: Engine cooling fan General Amphicar Discussion 0
B engine cooling fan General Amphicar Discussion 2
amphicarian Engine advice General Amphicar Discussion 19
DavidC Amphicar engine in Alabama General Amphicar Discussion 0
A engine milage and mechnical status General Amphicar Discussion 7
K Engine compartment paint. General Amphicar Discussion 2
W engine and transmision General Amphicar Discussion 4
C engine rebuild General Amphicar Discussion 1
C Underside hull paint and engine compartment paint General Amphicar Discussion 6
W engine manifold mystery General Amphicar Discussion 7
B SV: SV: Re: Engine cooling / Fan noise General Amphicar Discussion 0
B SV: Re: Engine cooling / Fan noise General Amphicar Discussion 1
D engine personalities General Amphicar Discussion 1
W Engine cooling / Fan noise General Amphicar Discussion 6
B 1147 cc engine advice needed General Amphicar Discussion 2
J Harley engine ---Lake Ozarks next week General Amphicar Discussion 1
B Engine Dies When Hot General Amphicar Discussion 9
S Wankel Engine in an Amphi General Amphicar Discussion 5
S Wankel Engine General Amphicar Discussion 3
S Engine gasket sets General Amphicar Discussion 1
