Tony Averbeck
I sure hope someone can help me with this one...
Get the Amphi running, rolling along at a nice speed and out of no where the
engine quits. Regularly, the blower motor kicks in imediately (should it do
that?) so I push the blower kill switch, turn the igintion and the engine fires
back up. The problem is that when that happens it will continue to happen
every 10 - 15 seconds until finally, the engine quits and I loose power
completely... no blower, no dashlights, no headlights, no nothing. Leave the
car sit for a number of hours and she'll fire right back up.
What's going on???
To date, I've replaced the voltage regulator (to fix another problem) and
cleaned all the wires and connectors on the switches that control the blower
motor - but the problem still persists. All the connections on the back of the
igition switch are clean and tight. What else should I check?
Tony Averbeck, cream '64, 512-413-8613
LAUNCH - Your Yahoo! Music Experience
What's going on???
