engine and transmision
wick68355@aol.com
Now that I have my engine out of the Amphicar, I decided to pull the trans to rebuild it. My question is, can the engine and trans go back in as a unit?
Tim(lotta work for the winter) Wick</font>
<font style="color: black; font: normal 10pt ARIAL, SAN-SERIF;"><hr style="MARGIN-TOP: 10px">See what's new at AOL.com and Make AOL Your Homepage.</font>
capon23@aol.com
Tim,
As a unit is the best way to put it back in...It is easier to put the transmission on the motor out of the car...I put a 1 X 6 old slightly oiled oak(hardwood)board on the flat area under the transmission and as you hoistmotor and tranny almost vertical you can slowly angle it into the car using the board as a sliding guide and when you get the transmission near the rear mounts go around inside the car and lift up the back of transby hand and place the 2 tranny bolts in place (when doing this you may have to lower hoist a little to line things up)... Now remove the board and lower engine totally on motor mount... I did this 3 times by myselfand it was flawless every time. Good point, Leave transmissionand motor empty of oilthen fill both when in car...
Good luck,
Cigarman</font>
rlgreen_55
Using a clutch alignment tool will assure that all is lined up
correctly and hopefully eliminate clutch shutter. Putting the engine
and tranny together before installing is the way to go.
trans
a unit?
> ************************************** See what's new at
http://www.aol.com
Tim,
The clutch disk alignment tool has EVERYTHING to do with getting the
engine and tranny together and NOTHING to do with clutch chatter.
> trans
> a unit?
> http://www.aol.com
Erik Mueller
RE: Re: engine and transmision
<table class="hmmessage">
<font size="4">
</font>How do you get off of the amphicar mailing list? It says "To unscubscribe send a blank email to...." and then it says "To confirm, reply to this message". I have done it multiple times, waiting about a week inbetween each time. It does not work.
-Sincerely
<blockquote><hr>To: amphicar-lovers@yahoogroups.com
Date: Tue, 16 Oct 2007 17:45:35 +0000
Subject: [amphicar-lovers] Re: engine and transmision
<div id="EC_ygrp-mlmsg" style="width: 655px;">
<div id="EC_ygrp-msg" style="padding: 0pt 15px 0pt 0pt; width: 490px; float: left; z-index: 1;">
<div id="EC_ygrp-text">
Tim,
--- In amphicar-lovers@<wbr>yahoogroups.<wbr>com, "rlgreen_55" <rgreen@...> wrote:
> trans
> a unit?
> > ************<wbr>*********<wbr>*********<wbr>******** See what's new at
> http://www.aol.<wbr>com
<span style="color: white;"></span>
</blockquote>
</br><hr></hr>Peek-a-boo FREE Tricks &; Treats for You! Get 'em!
