Emergency Brake Connection Plate
S
Scott K. Houghton
I am having a problem and hope that someone can help.
I am installing a new emergency brake unit on my Amphi. I have installed
all new cables, however I am missing the connection block (approx. 4" U
channel piece that all cables connect to).
Does anyone have this connection block that I can purchase? If not, I would
be interested in borrowing one so that I can have one made. Please contact
me at scotthoughton@wolinski.com or (313) 719-6500.
Thank you in advance.
Scott K. Houghton, PhD
WOLINSKI & COMPANY, C.P.A., P.C.
300 River Place, Suite 1400
Detroit, MI 48207
Phone: (313) 566-9000 ( Fax: (313) 566-9010
E-Mail: scotthoughton@wolinski.com
S Emergency brake cables substitutes? General Amphicar Discussion 0
S "Emergency" Override General Amphicar Discussion 2
S Fwd: Fw: EMERGENCY FRIENDS SYSTEM General Amphicar Discussion 0
