Electrical question
Mike Israel
Hi all,
Quick question.
On which side of the coil (positive or negative) should the thin wire from the
distributor (points) be connected? This is for a positive ground amphi with
original style ignition (points, condensor, etc).
Mike I.
Sent wirelessly via BlackBerry from T-Mobile.
Hi Mike,
With the original postive ground system, the wire to the points
should go to the + side of the coil. Just the opposite if the car
has been converted to negative ground.
--- In amphicar-lovers@yahoogroups.com, "Mike Israel"
<amphicar770@y...> wrote:
> Hi all,
> Quick question.
wire from the distributor (points) be connected? This is for a
positive ground amphi with original style ignition (points,
condensor, etc).
> Thanks,
> Mike I.
Amphipoda
Haven't been able to trace down the starting problem
but suspect it may be the bilge blower fuse.
Symptoms:
The blower blows and the override button turns it off just fine.
The engine will crank over but doesn't start (no spark at plugs).
The engine will start and run fine but only if I use a jumper wire
from ground to the coil (but the engine stays running after the key
is turned to `off').
Also, and this may or may not be related, but my bilge pump doesn't
work either.
Question:
Would the bilge blower fuse be the root cause for
both the no spark and the bilge pump issues? Is there an
easy override/fix someone can walk me through or diagram?
Thanks in advance.
Amphipoda
Jim Kelly
I had a similar problem with my 67 and suspected a bad ground. However, I completely jumpered out the vacuum tube with a separate switch for the blower. I can run the blower separately (just like a boat) and never be concerned that the car will not start when I turn the key. The vacuum tube is still there just in casesome future ownerwants theoriginal system with bypass switch. Jim
Amphipoda <Amphipoda@yahoo.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"><tt>Haven't been able to trace down the starting problem
Symptoms:
work either.
Question:
Thanks in advance.
Amphipoda
</tt></blockquote>
<hr size="1">Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
