Michael Echemann
Chuck:
I'm really not sure. I'm pretty good with everything automotive but
electrical problems are an exception. My knowledge is only good enough to
be dangerous and you don't need that right now. It seems as if it's a
problem caused by the dist. movement however I'm not sure why this would
cause it. Did any wires come off when you were making the adjustments? Did
you reconnect any removed wires correctly? I'm sure you did so this is
probably not the problem.
I hope you don't mind but lets send this one to the group. There's tons
of expert advice out there and it sounds like you need suggestions quickly.
Can anyone post some suggestions for Chuck.
Thanks, Mike
To: <echemike@earthlink.net>
Sent: Thursday, May 30, 2002 10:16 PM
Subject: electrical question
> Hi again Mike,
> I need help by the weekend if possible as I wanted to take the
car
> up to my in laws cottage on a small inland lake. The car was running very
> well after Dave's
> meet and last night I pulled the distributor and rotated the gear 1 tootth
> advanced
> and reassembled. So far so good. After ashort crank and no start I moved
the
> distrib towards retard and tried again. It fired up and ran for about 8
> seconds and felt like it had a lot more power. Took foot off gas and it
> stalled. Upon recranking
> it cranked hard like the distib had moved and was too advanced, let go of
key
> and it kept cranking for a few more seconds by itself and the battery
cables
> started to smoke and the insulation started to melt. HELP!!!!!! The
solenoid
> would only click
> after that. I put in a brand new battery today, tried again with only
three
> clicks of the solenoid and the cables got super hot again and all the
> insulation on the new negative cable melted off almost immediately. Just
> before the meet at Dave's I had installed a new starter solenoid and had
> rebiult the starter. Any thoughts? Could the solinoid have just fried? The
> points did not fuse together. Yes the battery cables are on correctly and
> were not touched before or after the dist. gear rotation.
Thanks, Mike
> Hi again Mike,
car
> well after Dave's
> advanced
the
key
cables
solenoid
> would only click
three
