David, thanks for the info.
I checked the engine serial # and its GK874HE. Not sure where that fits in
the production sequence but if engines were used somewhat sequentially then
this car might have been built in the 1st 1000 or so. I don't know where to
look for the transmission number and it will be a while before I can as the
seats are still installed.
What would be the measurements for a large driveshaft tunnel?
The bilge plug is approximately 30 mm in diameter. Not sure if that is the
large one or the small one. I would hate to think of one being smaller than
that
Brad
that
Brad
> They did use different VINs - and also it's not unknown for cars to have
> more than one vin number and even two cars to have the same vin number.
> Thing to remember is most of the cars were made in one batch probably late
> in 1962 when Amphicar were in "we will sell 20,000 of these a year" mode.
> The prop shields were only on cars that left the factory early - they were
> cut off all later cars as Amphicar works better without them.
> Larger driveshaft tunnels mean a later car.
> The flat side cars were all early.
> Chrome windows were an option.
> Red cars were a black dashboard were often earlier blue white or green cars
> resprayed.
> Early cars could jump out of gear as they didn't have a steady at the
> bottom of the water transmission.
> I think the best way to tell the age of an original car is the serial
> number of the engine and transmission - these seem to have been used
> sequentially. Most of my cars are late and had/have transmission numbers
> over 2000 but I do have an early transmission here (number 34) that looks to
> have been hand built.
> Engine numbers - earliest I've seen is GK150HE but there may be earlier
> ones about.
> There are sometimes date stamps on the brake backplates and the speedo -
> but these are when the components were made and so are normally 1961.
> Under the front seat there is sometimes a label and I have seen handwritten
> dates on these.
> Be aware that a German 1 looks like an English 7, the German 7 has a line
> through the middle.
> Cars with the flat sides are slightly heavier than those with the profile
> at the bottom and as a result don't drive quite as well although difference
> is very minor.
> Removing the rubber underseal saves around 30Kg which is noticable -
> (another reason why I always recommend against, epoxy paints, stone chip,
> por15, truck liner, thick marine paint and the like that people put on their
> Amphicars that just adds weight and that some poor sod will have to try and
> remove a few years later !)
> Oh - finally - Amphicar America and later Ranchero Motors would stamp there
> own "manufactured date" on the car at time of sale so it appeared fresh.
> David C
> ----- Original Message -----
> From: mike_israel
> To: david@manbus.com
> Sent: Thursday, July 23, 2009 8:58 PM
> Subject: RE: [General Amphicar Discussion-t-20495] Re: early / late
> Dave Chapman probably knows more but I recall that Amphicar used*two sets
> of VIN's based on which factory they were built at.*
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.5.392 / Virus Database: 270.13.25/2256 - Release Date: 07/23/09
> 06:02:00
