e-coating
  • Thread starter Thread starter Tom Jones
Tom Jones
Where in the mid-west can I get Finzilla diped & E-coated?? Thanx!! Tom
--- In amphicar-lovers@yahoogroups.com, "Tom Jones" <amphigill@...>
Tom
Tom,
DRM Electrocoat Corp in Reedsburg, WI. See www.drmindustries.com. I
have not used them, I just found thier info on www.electrocoat.org
John Bevins
Re: Re: e-coating
I am having my 63 dipped for rust removal at a cost of
$1500, please let me know what the e-coat cost is when
you find out. The estimate over the phone was of
course substantially lower for the dip.
Larry D
> <amphigill@...>
> E-coated?? Thanx!!
> Tom
> Tom,
> www.electrocoat.org
> John Bevins
________________________________________________________________________________\
____
Tonight's top picks. What will you watch tonight? Preview the hottest shows on
Yahoo! TV.
http://tv.yahoo.com/
If you're going to have your car dipped I would suggest you dtill
about a 1 inch opening on the top of each of the frame rails so that
you can get the acid out of them. They're not talked about as being
open to water and such but they are and if acid gets in, it probably
won't get out. These openings are also good for inspecting the inside
of the rails, which probably had water in them at some time anyway. I
did an article about this little talked about problem about 3 years
ago. You might check the back issues and learn about this issue.
For what it's worth, I wouldn't dip these cars and wouldn't sand blast
them either. The best thing for cleaning off the rust and paint it
SODA BLASTING. Soda is nice because it doesn't hurt the sheet metal
and the stuff that gets stuck under the frame rails will simply
disolve and wash out rather than continue to abraid the metal the way
sand will.
--- In amphicar-lovers@yahoogroups.com, larry depasquale
> Larry D
> > <amphigill@>
> > E-coated?? Thanx!!
> > Tom
> > Tom,
> > www.electrocoat.org
> > John Bevins
____
hottest shows on Yahoo! TV.
Replies
12
Views
1K
mstrug@juno.com
