dual su
David Derer
Linkage is super simple. Just add a bracket between carbs. Mine uses
bolts that hold on base of air cleaners. Then a hole in middle of
bracket holds the original style cable adjuster (threaded end piece).
Original accelerator cable works. But with out a bigger cam You wont get
full benefit. Plus Should upgrade to double valve springs. Later Dave
the Wave
uses
piece).
get
Dave
> the Wave
Dave - I just wanted to end the boiled carb thing. She has plenty of
power for me. If I feel the ned for speed, I get on my 110" (115HP/125
Ft/Lbs torque) Harley and twist the **** out of the throttle! ;)
