topless51ford
Hi All Again. Looks like the spare tire will not go in as designed but can shift forward and month on one of the lug nut holes. Is this what people do?
Master cylinder is from 68-69 VW Bus with manual brakes - Available new from Bughaus for $140 or rebuilt A-1 Cardonne #11-1558 from local parts store for about $30. 7mm Brake hose, 10mm bleeder(to close off extra rear outlet) and nylon master cylinder connector pipes (small) all came from Bughaus. Lines from reservoirs to master cylinder formed from 40 inch pieces of 1/4" steel brake line. Plunger from brake pedal needs to be turned down slightly or master cylinder piston drilled out slightly for proper mating. Pretty simple and straight forward.
Ted
You'll need a dual master cylinder for a 68-69 bus: https://www.bughaus.com/master12.htm
Connecting pipes (elbows): https://www.bughaus.com/master_cylinder_connecting_pipe_-_113611153.htm
That fit into grommets: https://www.bughaus.com/brake19.htm
These are the parts I used in my dual master cylinder conversion.
You'll also need a dual reservoir (or another single). This is the one I used: https://www.bughaus.com/brake_fluid_reservoir_-_113611301L.htm
along with a custom bracket to mount it where the existing reservoir is located.
Gut them and then they are just adaptersAha! - found the answer! - They are "residual pressure valves": small check-valves, designed to keep a little bit of pressure in drum brake lines to reduce excell pedal "travel" or the need to "pump up" the brakes if they pull a but too far away after sitting. They were a feature on the 68/69 era VW master cylinders for VW's that had 4 wheel drum brakes. They eventually eliminated them, when brake servos became more popular. Amphicars are not too picky, and have effective brake-shoe adjustment cams to keep the shoes just barely away from the drum. The RPV's can be left as-is... but might make air-bleeding tougher, so here is a thread where they are gutted and used simply as pass-thru adapters (because that model 22mm dual master cyl is drilled for M12 to accept the valves...but Amphi brake line fittings are M10 - so you DO need the hex shaped metal nut to screw into!
see: https://www.thesamba.com/vw/forum/viewtopic.php?t=476304
@David T Glad it wasn't that hard. I purchased the master cylinder last month for future use and am going to swap it this winter. I can't locate most of the items on Bughaus (or bugstuffonline) using any of your BOM part numbers. They don't even show a reservoir that looks anything like yours that I can find. It looks like it must not have a cap and instead has an inlet hose that you feed off of the original reservoir. Is that correct? Does it have 2 fittings on the bottom that "plug in" to the top of the MC?I have attached pictures and ordering information for all of the parts. I turned the outside of the Dorman adapter to 1/2" OD and drilled the other end so the fitting would thread into it. That connected the original reservoir (with a hose) to the new dual reservoir on the new master cylinder. I turned down the plunger so it would fit nicely into the new BMC. The brake lines have to be bent a little to fit without cutting. The residual pressure valves were removed to make bleeding easier. I suggest obtaining all of the parts before you do the conversion so you can get the car drivable quickly, the actual work doesn't take that long to do. Before doing anything you should make sure the brake system functions correctly, installing the dual BMC will not fix a non-functioning system. I stuck wheel cylinder piston will still be stuck, a broken or missing spring will still be missing or broken. Old, rotten brake hoses should also be replaced.
