So I bought the aforementioned, and successfully used dual circuit Cardone 11-1558 MasterCylinder from amazon last year, and kept it safe till this past week when i was ready to put it in.
Then i noticed something: The original master cylinder (reportedly the same one VW used on early/50's split-window buses)..has tapped holes that the brake fluid travels thru.
But the dual circuit unit that folks here have used (reportedly used on 68&69 vw buses), has these mysterious valve-like devices that the lines screw into, rather then just screwing directly into the cast Master cylinder.
I had trouble not being able to purge air out of the front chamber that feeds the fonts (or maybe getting air leaking back in), so i tried to bench bleed it....but was still getting a sucking sound, and air in the front chamber. So i emptied it out and said "what the hell are these gadgets anyway, are they causing the problem? They arent on the original master". So i removed them out of curiosity and tried blowing thru them , and to the mils capabilities of human mouth-pressure, are much more resistant to airflow than the original master that blows as smooth as a straw!
What the hell are these things?....and could they be causing air to be sucked back in? (ps - i ordered another master from a place that sell new ones, in case the seals on the Cardone reman one are bad(
But what are these restrictive devices that are not on the original masters?
