LSolheim
Putting things back together after the early spring/post winter maintenance and ran into something unexpected.
The RR drum seemed to go on OK, but as I tightened the drum attachment screws I felt rotational interference. At first I expected brake shoe interference, but that doesn't seem to be the case. She rotates OK with the screws loosened, but tightens up when the screws are tightened. Once the wheel is attached @ 87ft-lb things do not improve.
Went for a short test drive to see if it would fall into place, but the drum heated up unacceptably.
I don't recall this from last year. Certainly the axle couldn't have moved or be too far to the inside or it wouldn't fit properly into the tranny.
Any ideas out there?
--Larry
--Larry
