Drive Tunnel Boots
Tedredamphi
Does anybody know the exact diameter of the "Drive Tunnels" that the boots fit over? I know that a 4 inch boot fits, but was wondering if a 3-1/2 inch boot might fit? See attached picture!!!
Ted
CapnJohn
Ted
Whatever you use it MUST be resistant to grease and oil and be able to take the heat as well.
Canadian four amphs
Go to my web stie.. Click on the Red car at top of this page,
Go into my Parts list.
near the very top is a part # for Volvo penta, bellows..
They will work on Amphicars and a designed to do the very same job on boats,,
they are a bit bigger but will tighten down perfect if you are carefull. alway double check and 1st water test you should alway look for leaks..
GORD.
