tazman3115@aol.com
I found that the easiest way to release the drive shafts from the
transmission per Paul R was to remove the 6 or so osillating arm bolts and pull
the arm
away from the body enough to pull the end of the shaft from the trasmission so
you can remove the trans. Note I did not even release the tension from the
brake cable or brake hose and had no problem. I may have too much cable slack?
but the job of pulling the drive shaft out to replace the double lip seal went
well thanks to Paul. My 2 cents worth, Chuck.
PS are local homeless program is sponsoring a fund raising golf outing. We
are going to have an extra fund raising drawing with the prize being a lenghthy
Amphicar ride to the high bidder. I think this will work well.
the arm
