Drive Shaft Tunnel
PeterP
When did Gordon Imports start making a replacement driveshaft tunnel?! I had to have one custom welded last year, and though the guy did a good job, it's not half as nice as that.
I am seriously considering cutting the replacement one out and welding in Hughs.
*Grumble Grumble wasted money Grumble*
I don't remember him making a big noise about their availability though so perhaps he just found a box of them in his big (but only somewhat organized) warehouse.
Akamphi Amphicar Drive Shaft Type General Amphicar Discussion 8
Akamphi Drive shaft rebuilding General Amphicar Discussion 6
W Drive Shaft U joints General Amphicar Discussion 2
J Late Style Drive Shaft Universals General Amphicar Discussion 7
S Looking for a drive shaft General Amphicar Discussion 1
R drive shaft General Amphicar Discussion 1
R Drive shaft slip-joint grease fitting General Amphicar Discussion 1
SNOWBIRD 28MM drive shafts General Amphicar Discussion 3
Jon March Water trans drive gear retainer clips: General Amphicar Discussion 7
M water drive switch General Amphicar Discussion 4
B 101 Cars you must drive General Amphicar Discussion 3
T Drive Tunnel Boots General Amphicar Discussion 2
J A Long Drive To Be Sure General Amphicar Discussion 0
C Amphicar drive shafts General Amphicar Discussion 3
D long drive General Amphicar Discussion 0
E Concours on Rodeo Drive, Beverly Hills General Amphicar Discussion 0
T My drive shafts are hanging out General Amphicar Discussion 0
A Right Hand Drive Amphicar General Amphicar Discussion 0
M MISC. STUFF and My Right Hand Drive Amphicar General Amphicar Discussion 3
S Rear Drive Shafts Resting on Tunnel General Amphicar Discussion 2
W final drive ratios General Amphicar Discussion 16
T Drive Shafts General Amphicar Discussion 10
A Long drive... General Amphicar Discussion 7
R First drive General Amphicar Discussion 1
B 4 wheel drive Amphi General Amphicar Discussion 0
A Drive train installed ... FINALLY! General Amphicar Discussion 0
M Amphi Test Drive General Amphicar Discussion 1
B Club Page Makeover and Membership Drive...Er...Swim... General Amphicar Discussion 0
Jacques B. Amphicar Axle shaft removal from the gearbox General Amphicar Discussion 5
sdreich Crank Shaft Bushing Recourse General Amphicar Discussion 5
T Propeller Shaft Seal Installation General Amphicar Discussion 22
T Prop shaft questions please General Amphicar Discussion 11
C shaft rotation General Amphicar Discussion 2
L Decals (was Re: Noisy Prop Shaft Tubes) General Amphicar Discussion 2
L Noisy Prop Shaft Tubes General Amphicar Discussion 1
A Prop Shaft Bearing 3-19-2 Grease General Amphicar Discussion 1
C Axle shaft removal General Amphicar Discussion 4
C Prop shaft torx bolts... General Amphicar Discussion 4
B SV: SV: SV: Propeller Shaft U-Joints General Amphicar Discussion 0
B SV: SV: Propeller Shaft U-Joints General Amphicar Discussion 1
B SV: Propeller Shaft U-Joints General Amphicar Discussion 3
A Propeller Shaft U Joints General Amphicar Discussion 1
S Propeller Shaft U-Joints General Amphicar Discussion 0
E Transmission Input Shaft Radial Play General Amphicar Discussion 1
E Inspecting Prop Shaft U-joints General Amphicar Discussion 0
T Propellor Shaft U-joint Bolts General Amphicar Discussion 6
R Distributor Shaft Woes General Amphicar Discussion 6
M Tool needed @ Celina for prop shaft assembly General Amphicar Discussion 0
