rogtwo@aol.com
I suspect this has been covered before, but being an Amphicar newbie,
hopefully someone will fill me in.
I removed the one drive shaft from my Amphicar to replace the slip-joint
boot. I have two questions about this:
1. The drive shaft I'm working on doesn't have a grease fitting for the slip
joint. Should I drill a hole and install a zerk fitting for the slip joint?
2. I see Gordon's sells "ribbed hose" for the slip-joint boot. I was
thinking of using the boot from a Subaru rack-and-pinion steering gear. Has
anyone else found a better substitute for this boot than Gordon's hose?
Roger Seattle
Roger Seattle
