Double lipped seal install tips
gzink
Replaced double lipped axle seal a couple of times. Always a pain forcing it in w/o damaging. Should I freeze it to shrink, boil it in water to make plyable? Tips from experts appreciated. Also any foolproof tips on removing
Jon March double the fun: 2 kinds of ignition wires! General Amphicar Discussion 0
G Double Lip Oil Seal General Amphicar Discussion 1
R double axle trailer General Amphicar Discussion 1
S Double clutching and Synchromesh General Amphicar Discussion 0
K Double clutching demystified General Amphicar Discussion 3
T Double lip seal General Amphicar Discussion 5
B Water/land tranny seal Restorations in progress 15
B door seal test Restorations in progress 1
R hood seal on the body General Amphicar Discussion 1
Jon March Seal types - good info General Amphicar Discussion 0
Jon March when driveshaft seal-areas corrode General Amphicar Discussion 18
Jon March Seal popped out of hub!? General Amphicar Discussion 4
T Door Seal Question? General Amphicar Discussion 5
T Propeller Shaft Seal Installation General Amphicar Discussion 22
D Trans seal General Amphicar Discussion 1
G door seal update General Amphicar Discussion 5
W seal replacement General Amphicar Discussion 1
B gas shut off seal disk General Amphicar Discussion 4
E Front Wheel Grease Seal General Amphicar Discussion 0
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
G Seal between water and land trans General Amphicar Discussion 7
A Front wheel bearing seal General Amphicar Discussion 2
M New door area seam seal mouldings from Hugh. How to install?? General Amphicar Discussion 4
A Window Seal Track needed. General Amphicar Discussion 0
B rear axel seal replacement General Amphicar Discussion 0
B transmission axel seal replacement General Amphicar Discussion 1
J Rear Wheel Bearing Seal Orientation General Amphicar Discussion 1
T seal puller/prop removal General Amphicar Discussion 0
D Exhaust Seal General Amphicar Discussion 0
M Transmission Oil Seal General Amphicar Discussion 0
