Double lip seal
Taylor, Craig M.
I'm going to be taking my 66 for it's first swim when I get home from work
and was wondering if there was any way to test the tranny seals. I'd like to
know before water is pouring out the starter if they are bad? I'm going to
use a garden hose to check the bilge for leaks. Any areas to pay close
attention too that I might not think of?
Thanks, Craig
Remove the back seat and make a dip stick so you can easily check the level of
oil in the land transmission (I think the dimensions are on my website somewhere
but you can probably work it out yourself). Then check it on level ground just
before you go in, have a dip for a couple of minutes, come out and check again,
you are looking for the level rising and/or the oil turning white and creamy. If
all is well go in for longer but check again before driving home. If you have
water in the trannie don't drive unless you really have to, better to get a
recovery truck and drain and change the oil as soon as you can.
If the seals are really bad then oil runs down the driveshaft tunnels and drips
by the rear wheels, also when afloat, water comes out the top of the land
trannie life a fountain !
From: "Taylor, Craig M." <taylorcm@alyeska-pipeline.com>
Sent: Sunday, April 14, 2002 5:19 PM
Subject: [amphicar-lovers] double lip seal
Thanks, Craig
THE AMPHICAR-LOVERS LIST
Taylor, Craig M.
Thanks Dave, I hadn't thought of checking the oil level. Silly me I was
thinking up all kinds of pain in the rear techniques.
Craig, waiting for break up in Alaska...
-----Original Message-----
Sent: Sunday, April 14, 2002 9:22 AM
Subject: Re: [amphicar-lovers] double lip seal
of
somewhere
just
again,
creamy. If
have
drips
Thanks, Craig
tommyintpa@aol.com
In a message dated 4/14/02 10:30:08 AM Pacific Daylight Time,
taylorcm@alyeska-pipeline.com writes:
> drips
> David Chapman
Hi, I was thinking, if you run the car until the transmission is good and
hot, I mean 60 mph for 20 minutes, so it is hot and the oil is thin. Then
lift the car so that the rear tires are hanging, turn them a few times around
and let them hang. After a couple minutes get a flash light and look up the
tunnel for any sign of fresh oil. Take a good look at the drive shafts check
to see if they look the same. Are they in the transmission the same amount?
Do the shafts look the same? Did the drive shafts scope out the same amount?
If one tire is even a little higher it may be that a shaft is not sliding out
fully and you will get water in the trannie.
See ya, Tommy in Tampa - took the red 67 for a 3 1/2 hour 12 mile cruse today
Randy Bograd
What's the proper depth for seating the double lip transmission seal?
Right now the seal is flush with the tranny's surface.
thanks,
Randy
Blue '67 in Gaithersburg
tommyintpa@aol.com
In a message dated 11/30/02 1:14:44 PM Pacific Standard Time,
rdboggie@juno.com writes:
> thanks,
> Randy
Hi Randy,
That is the way we have always installed ours.
Two things, you will want to coat the seal lips with grease as the outer lip
does not get any lube if the inner lip is doing its job and will mark the
shaft.
If you are using your old shafts they will probably have a groove from the
outside lip of your old seals. I always try to remove that groove using Emory
paper or better yet a die grinder with a Scottish Bright pad attached. It
always surprises me that the rubber seal will make that groove and still be
water tight. When you go in the water the seal has to stretch to come out of
that groove and the shaft is a little larger so it stretches the seal, then
out of the water the seal has to shrink back to fit the smaller groove.
If you have your tranny out put the drain plug back in before you reinstall
it. You don't want to do your contortionist act to get that bilge'n plug in.
Good luck, Tommy in Tampa
G Double Lip Oil Seal General Amphicar Discussion 1
Jon March double the fun: 2 kinds of ignition wires! General Amphicar Discussion 0
R double axle trailer General Amphicar Discussion 1
S Double clutching and Synchromesh General Amphicar Discussion 0
K Double clutching demystified General Amphicar Discussion 3
B Water/land tranny seal Restorations in progress 15
B door seal test Restorations in progress 1
R hood seal on the body General Amphicar Discussion 1
Jon March Seal types - good info General Amphicar Discussion 0
Jon March when driveshaft seal-areas corrode General Amphicar Discussion 18
Jon March Seal popped out of hub!? General Amphicar Discussion 4
T Door Seal Question? General Amphicar Discussion 5
T Propeller Shaft Seal Installation General Amphicar Discussion 22
D Trans seal General Amphicar Discussion 1
G door seal update General Amphicar Discussion 5
W seal replacement General Amphicar Discussion 1
B gas shut off seal disk General Amphicar Discussion 4
E Front Wheel Grease Seal General Amphicar Discussion 0
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
G Seal between water and land trans General Amphicar Discussion 7
A Front wheel bearing seal General Amphicar Discussion 2
M New door area seam seal mouldings from Hugh. How to install?? General Amphicar Discussion 4
A Window Seal Track needed. General Amphicar Discussion 0
B rear axel seal replacement General Amphicar Discussion 0
B transmission axel seal replacement General Amphicar Discussion 1
J Rear Wheel Bearing Seal Orientation General Amphicar Discussion 1
T seal puller/prop removal General Amphicar Discussion 0
D Exhaust Seal General Amphicar Discussion 0
M Transmission Oil Seal General Amphicar Discussion 0
