Door Seal Question?
Tedredamphi
:032:Which way do the door seals fit onto the driver and Passenger door? Lip out as in picture one or lip in as in picture 2? I'm guessing door #1 is correct, but would rather have an answer from someone that knows for sure.
My doors had no seals when I bought the car and the previous owner had taped the outside of doors with duct tape for his one and only swim.
Ted
Ron Green
The picture on the left is correct.
Prior to installing these critical seals I allow the paint to cure, lightly sand (tooth) both the rubber and paint area where the rubber attaches to, pre-fit the seal to make sure all is well, clean both the seal and area glue will adhere to with lacquer thinner on a clean rag, use yellow 3M weatherstrip adhesive (new formula is ok as old formula is getting hard to find), start at the top and work your way around being careful not to stretch the rubber in the corners, apply strips of decent masking tape on the corners, etc to make sure the seal remains in place, shut the door if mounted. Allow to cure at least 24 hours and remove the tape.
Good luck!
Canadian four amphs
Pic on the Left is correct...
Do not glue in till you do the paper test to make sure it is a tight fit all the way around, if there is loose spots use a fill material behind this rubber in that area.GORD
jwillia
How do you do the paper test ? Thanks Jeff
To: jeffreyd_7@hotmail.com
Subject: RE: [General Amphicar Discussion-t-20363] Re: Door Seal Question?
Date: Fri, 20 Mar 2009 11:25:16 -0400
Tedredamphi
Gord,
How do you get this seal to stay in place for a paper test if it is not already glued to door?
Ted
Midwest Amphicar
I do not know where You got seal, but I know Your picky. Some aftermarket is too stiff = bouncy= hard to close door. Use an easy to remove glue or just tape for trial. Later Dave the Wave
B door seal test Restorations in progress 1
G door seal update General Amphicar Discussion 5
M New door area seam seal mouldings from Hugh. How to install?? General Amphicar Discussion 4
MAE Right Side Door Needed General Amphicar Discussion 0
R door panel springs General Amphicar Discussion 3
B Door glass pattern needed General Amphicar Discussion 3
Akamphi Windshield and door handle instal General Amphicar Discussion 1
T Amphicar door installation General Amphicar Discussion 6
T Door Mounting Question General Amphicar Discussion 1
A Door County Maritime Museum Boat Show General Amphicar Discussion 0
C Door hinge General Amphicar Discussion 1
G door seals and vapor lock General Amphicar Discussion 0
A Vent frames and door handles needed General Amphicar Discussion 2
F water door lock General Amphicar Discussion 0
L Door Glass 11-36-24 General Amphicar Discussion 0
S Door Skins General Amphicar Discussion 1
P Amphicar Door Repairs General Amphicar Discussion 0
B DOOR LEAKS....AGAIN! General Amphicar Discussion 0
R door panel General Amphicar Discussion 0
S new door panel boards General Amphicar Discussion 1
W body to door seals General Amphicar Discussion 2
M door latch problem General Amphicar Discussion 0
J DOOR ALIGNMENT General Amphicar Discussion 0
J Wider Simulated Chrome Door Edge Guards General Amphicar Discussion 0
D wow what a day plus NEW door handles General Amphicar Discussion 0
T DOOR PANEL WANTED General Amphicar Discussion 0
D Door Leaks Finally FIXED! General Amphicar Discussion 2
J Pole light door seals General Amphicar Discussion 2
C Door lock cylinder... General Amphicar Discussion 6
R Door handle spring General Amphicar Discussion 3
A Ignition switch and door locks General Amphicar Discussion 9
W Out door Wisconsin General Amphicar Discussion 1
D door memory General Amphicar Discussion 0
R Replaced door seals. General Amphicar Discussion 0
R door seals General Amphicar Discussion 11
D three holes on the body by the door General Amphicar Discussion 1
K white door mouldings. General Amphicar Discussion 0
J Inner Door Seals General Amphicar Discussion 0
J White Door Surround Stripping General Amphicar Discussion 0
C Door lock trouble General Amphicar Discussion 1
M Clock and Glove Box Door Needed General Amphicar Discussion 8
D Door skin General Amphicar Discussion 0
M Pump & Door Seals General Amphicar Discussion 1
D Door catches General Amphicar Discussion 0
P Glove Box Door General Amphicar Discussion 0
G Double lipped seal install tips General Amphicar Discussion 0
B Water/land tranny seal Restorations in progress 15
R hood seal on the body General Amphicar Discussion 1
