Craig Taylor
Looking for some advise guys. The passinger door on my 66 wont latch
fully without using the water lock. I have found that the lower
attaching screew for the lock mechanism, in the door, must have
loosened up in the past and has oblonged the mounting hole. Closing the
door results in the lock moving and not fully latching. The mounting
hole is pretty screwed up with a 3/4 inch crack running down below it.
Is this a common problem? Any ideas on how to fix it? I'm not sure that
it could be welded up without messing up the lock or mounting hole. I
imagine it has to be just right or the lock wont work. Maybe I can get
a small patch piece from someones Rusty door and have it welded in. I'd
like to make it as good as new. Any ideas?
Thanks
Craig in Alaska
Red 66
Thanks
Craig in Alaska
Red 66
