Door catches
DAVIS,BRIAN R
My left door doesn't always close all the way without lifting it slightly as
I slam it. Upon investigation, I noticed that there is a grove worn in the
top of the catch (that's the piece that's attached to the body). The groove
was worn by the door latch rubbing on it.
This all translates to a situation where the door isn't lifted quite high
enough as it latches. As a result, the ratchet wheel doesn't engage
properly.
Have any of you noticed this, or had similar problems?
Have any of you ever tried adding some material back on top of the catch by
welding it and grinding it down?
Thx, Brian Davis
Red '66
