Differential Cover
okey0
I was scraping the old gasket off the differential cover, and in doing so, realized there were actually 3 separate gaskets in place. Does the diff. cover require some sort of exact spacing that would require the use of 2 extra gaskets?
On the Diff. and on the front plate of trany gaskets are used for shimming.
there were 2 different thickness gaskets. If you are not changing any bearings or gears then the same amount should go back in, If not trany needs to be re shimmed.
I stock most trany gaskets and seals.
Some NOS gears too,.
