Crankcase vent hose, from valve cover to ????
I have an original valve cover with the connector for the vent hose, but dont know where to put it. My repro aircleaner doesnt have a nipple on it nor does another original one I have. I also have 2 my spark arrestors and neither has a place for the hose! Thanks!
Canadian four amphs
you will have to weld a small bent pipe into air filter bottom to make it work.
also check that vent pipe to bottom is now closed off(below manifold at rear)
GORD
cigarman
If you don't want to weld, just go to a auto parts store and get a size you need pvc fitting elbow with tightening nut. and you can just drill a hole in the bottom of the air cleaner for your application..
Cigarman
