DougFromBaltimore
Convertible top - Help with weather-strip over side windows – Any suggestions on how to install them?
I’m replacing the rubber weather-strip (part # 12-45-16) that goes over the side windows, and attaches to the bottom of the convertible top frame with aluminum channels. I purchased new weather-strip from one of my favorite big suppliers. It will not slide in. It is more firm than the original rubber, is very slightly larger, and the original was arched on the bottom. I’ve tried warming it in hot water and using soap. And I’ve replaced the oval top screws that intrude into the channel with flat top screws. Also, smoothed off any sharp or rough edges in the channels. I can’t get it in more than one-half inch!
It looks like my only option is to sand/shave down the two sides (especially the pointy side) that go into the channel, and arch the bottom. I’ve set up jigs on my drill press, and am using two sizes of sanding drums, with the speed set to high.
Before I attack and make these expensive parts unreturnable, are the any suggestions?
Thanks, Doug
Thanks, Doug
