Convertible Top frames
Never had this before!
the holes for hold downs were in the wrong place(from new)
instead of being in line with the pins they were to the outside of it.
so as in picture I cut open the top and made a new inset and welded it in place with the 4mm hole for hold down hinge.
Gord,
How could such an error occur at the factory? If I understand the error, they wouldn't have been able to put the top up for shipping. Some switched part seems more likely. Perhaps I don't exactly understand what the error is.
Kruser
as per Hugh and Bob Gordon they have new convertible top bows that they picked up when they bought up the left over factory inventory that are all like what Gord had above. Bob told me the way late models had the offset pins and latches. My car didn't come with a top and was looking for the bows when I got that info, I end up getting good used bows from Bevins in the end and never did deal with the issue. I'm just guessing the Amphi engineers thought offsetting pins and latches would help strengthen the front header on the bows?? That reminds me that I have a set off spare convertible top bows I got from Capone that he robbed the front header off of (the part that usually goes bad). If someone wants them, come and get em ( so I don't trip over them for the next 40 years)
Never done till you are done.
Fit doors on and Alu, hits the vent window had to cut and reweld.
Electron top has a good note on fixing the sag above front side windows.
i will see if I can get the club to re print it in the newsletter.
DougFromBaltimore Convertible top - Help with weather-strip over side windows General Amphicar Discussion 4
Akamphi Convertible top straps General Amphicar Discussion 0
jfriese Tips For Installing The Convertible Top General Amphicar Discussion 3
azpaul50 Convertible Top Frame General Amphicar Discussion 3
J Convertible Top Question General Amphicar Discussion 12
G Convertible Top Question General Amphicar Discussion 1
J Convertible top General Amphicar Discussion 6
D Wanted 1985ish K car convertible For sale Amphi Tow vehicle General Amphicar Discussion 0
D Atlanta Road trip convertible top General Amphicar Discussion 1
M Black Convertible Top General Amphicar Discussion 1
R convertible top problem General Amphicar Discussion 5
T Convertible top question # 2 General Amphicar Discussion 1
S Convertible top color General Amphicar Discussion 1
M Convertible Top Frame General Amphicar Discussion 1
Jon March rust and scale in frames? Try new Rust Twister ! General Amphicar Discussion 0
T Vent Windows and Frames General Amphicar Discussion 11
A Vent frames and door handles needed General Amphicar Discussion 2
L Wanted: Chrome window frames General Amphicar Discussion 0
