L
Larry & Nancy Solheim
Just received my new P185/80R13 radials, but have discovered that the wide white
sidewalls are 2-7/8" wide rather than the 2-1/4" width per the tire spec and
Amphicar standard. When called, the customer service folks at Coker seemed
surpirsed and confused. I figure if I'm going to have the wrong tire, I might
as well have the $30.00 readily available blackwall as this nearly $150.00 (w/
freight) tire.
I thought the nearly 3" white sidewall looked EXCEPTIONALLY large on the 13"
tire. From those of you buying these in the past, have the whites always been
oversized? I suspect this is a new batch that was incorrectly made and they
maybe hoping to sell them. Almost impossible to believe that no one knew about
it.
I'm a bit nervous about the tracking issues recently posted about radials.
Since 1993 I' ve put over 45,000 miles on the bias belted Coker Classics
(driving and flat towing); the car tracks great (except for the bias belt
practice of following road defects), but I'm hard pressed to get 25,000 miles on
a set. I was hoping the radial sidewalls would put less load on the suspension
by absorbing some road imperfections and the overall wear would improve.
--LarryS
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
freight) tire.
it.
--LarryS
Do you Yahoo!?
