clutches
Allan Woodcock
This is only one opinion. The Amphicar clutch connects an English
engine with a German tranny so it is not your average clutch. The
rebuilt clutch pressure plates that Gordon's sells are excellent. Some
of the parts such as the springs may not be availible to the averge
clutch rebuilder. Since a smooth clutch is essential I would recommend
Gordon's on this one.
Allan
Red '66
morgschulz2000
What is the current thinking on clutches? Are new ones available?
If so, where? If not, what are the recommendations on having them re-
faced?
Gary Schulz
Green '67
Michael Echemann
Gary:
I've heard a lot of problem clutch stories over the years mostly because
folks tried to have them rebuilt locally etc. I'd go with Gordons or send
Dave the Wave Derer dmd@essex1.com an email for information. Dave seems to
have a source for rebuild which work well. I'd stay with these two options
specifically regarding your driven plate.
Sent: Sunday, April 28, 2002 10:06 AM
Subject: [amphicar-lovers] Clutches
> faced?
> Gary Schulz
> Green '67
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> amphicar770@yahoo.com
buoyant3
I put a new clutch and pressure plate in last year that I purchased
from Mr. Dave the Wave. It all went back together as planned and
worked well all summer. Dave will tell you how each aspect of the
replacement must be watched carefully, secured equally and slowly.
I'm sure Hugh Gordon has a quality clutch too. I chose Dave's
because I needed it the same day and he is only a drivable 100 miles
away.
That's my 2 cents worth.
Marty
re-
> faced?
> Gary Schulz
> Green '67
amphiguru
Earlier today, I enjoyed talking with John Friese, and the subject
of clutches came up. Just for the record, I have one of John's
clutch systems in my Amphicar, and I am very satisfied.
Here are the relevant guide lines regarding original clutches versus
John's. Use John's under the following circumstances: (1) 1300 or
1500 engine, (2) your car is totally dry, and (3) never used in salt
water. Use original under the following circumstances: (1) 1147cc
engine (You can still use the Friese system if you wish.), (2) your
car leaks or you boat in "off shore" conditions, and (3) price is an
issue (although I feel John's is fairly priced for the features he
provides).
While you can use an original system in a 1300 or 1500 engine, it
was not designed for the additional power requirements. John's is
the correct system for these more powerful engines.
The dry car-water issue arises due to the different type of release
bearing used in the two systems. The original was carbon. It had
no moving ball bearings to rust or seize. John's system has a
superb roller bearing, which when dry is superior to the carbon
type. It's a little like a water "resistant" watch. An occasional
spray won't be a problem. However, get enough water in the bilge
and the flywheel will act like an old paddle wheel steamer, bathing
the roller bearing in a constant shower of water.
Another thing to remember is John's system is all new parts. Our
system is a rebuild. You should expect more consistency with all
new parts.
Hope this helps. We offer both the original and Friese system in
our parts program. Call, fax, or e-mail if you've got additional
points.
P.S. Don't forget (those of you who have bought the Friese system)
to send us your old clutch parts. You will be paid by us as
follows: 1-12-11 disc core = $25.00, 1-12-01 pressure plate core =
$25.00. This will reduce your cost by $50.00 and help ensure
original parts availability in the future.
Hugh
Replies
3
Views
472
Larry & Nancy Solheim
L
Replies
3
Views
773
Bill Connelly
