Clutch
How to True up the clutch on original Amphicars. I forgot to do this and had to pull the motor back out to set it true. I usually use what we call the John Friese cluch kit witch does not need this step. and then when I put it in the 2ed time the front seal on trany popped out. Had to pull motor a 3ed time!Freds final day 002.JPG
Over the years I also chased a clutch chatter problem pulling the engine several times with no luck.
Until I got the Friese clutch and installed it that is, now it works great!
X clutch stuck ? General Amphicar Discussion 4
Jacques B. Amphicar pressure plate and clutch disk General Amphicar Discussion 3
DavidC Foot off the clutch. General Amphicar Discussion 28
T high performance clutch General Amphicar Discussion 0
azpaul50 Clutch Adjustment General Amphicar Discussion 26
A Carbon Clutch Release Bearing General Amphicar Discussion 0
D Clutch not available General Amphicar Discussion 3
J High Performance Clutch Kit General Amphicar Discussion 0
G high performance clutch and power General Amphicar Discussion 1
D fight ing the clutch cable General Amphicar Discussion 3
L Clutch and carb question General Amphicar Discussion 2
B SV: Re: clutch cable General Amphicar Discussion 0
T Clutch advice PLEASE General Amphicar Discussion 2
A Clutch cables, cleaning props, nut wrench size, release bearings General Amphicar Discussion 0
R Clutch in....No Clatter! General Amphicar Discussion 2
S clutch cable General Amphicar Discussion 13
E Clutch Housing Bolt Removal General Amphicar Discussion 1
D Clutch Information General Amphicar Discussion 0
B Accelerator/Clutch Problem General Amphicar Discussion 1
A CARBON CLUTCH RELEASE BEARINGS General Amphicar Discussion 1
J diaphram clutch General Amphicar Discussion 3
B Transmission and Clutch General Amphicar Discussion 0
T fix your clutch shudder - like this General Amphicar Discussion 0
P Clutch pedal is fixed - must find new way to exercise left leg! General Amphicar Discussion 3
B Celina tech on clutch chatter General Amphicar Discussion 0
A Clutch Judder General Amphicar Discussion 0
S In car clutch adjustment General Amphicar Discussion 1
S Clutch Adjustments (long) General Amphicar Discussion 2
T I need clutch help - PLEASE General Amphicar Discussion 6
A Hydraulic clutch? General Amphicar Discussion 1
S Clutch Adjustment? General Amphicar Discussion 0
M Clutch disk thickness General Amphicar Discussion 1
M Clutch Question General Amphicar Discussion 2
M Clutch Shudder General Amphicar Discussion 2
A clutch problem General Amphicar Discussion 3
S shift linkage/clutch cable General Amphicar Discussion 1
K Amphi clutch General Amphicar Discussion 0
A clutch trouble General Amphicar Discussion 1
D Clutch General Amphicar Discussion 18
M Clutch Problems Magnified General Amphicar Discussion 0
