Clutch pedal is fixed - must find new way to exercise left leg!
  • Thread starter paul.j.rasmussen@GM.com
  • Start date
P
Well I took Dr. Gordon's suggestion and flipped the clutch linkage triangle
cam piece under the floor around 180 degrees.
Clutch pedal effort went from 'grab on to the steering wheel and push' to a
nice soft pedal effort. Only problem now is wife will want to drive the
car all the time. High clutch pedal effort dampened her enthusiasm for the
car previously. Might have to keep an eye out for another car for me now
(what a problem to have). See what you have done Hugh (kidding)
Again, thanks Hugh - does this mean I will have to find another leg weight
training device with the clutch totally fixed? Left leg was getting
significantly more muscled out than the right - big problem you know,
special pants for the left leg, left shoe sole wearing out faster than
right, etc.
PJR
Red '62
Rambling around in Rochster (MI)
P.S. Saw a '68 motorized surf board on eBay - would this be fun to have
behind the A-car?
Jon,
At sometime in this cars past someone had the clutch pedal linkages, under the toe board floor, apart and when he reassembled the car he installed two triangle pieces incorrectly. This messes up the leverage that the clutch pedal has and caused his heavy clutch pedal problem.
SNOWBIRD Clutch General Amphicar Discussion 2
X clutch stuck ? General Amphicar Discussion 4
Jacques B. Amphicar pressure plate and clutch disk General Amphicar Discussion 3
DavidC Foot off the clutch. General Amphicar Discussion 28
T high performance clutch General Amphicar Discussion 0
azpaul50 Clutch Adjustment General Amphicar Discussion 26
A Carbon Clutch Release Bearing General Amphicar Discussion 0
D Clutch not available General Amphicar Discussion 3
J High Performance Clutch Kit General Amphicar Discussion 0
G high performance clutch and power General Amphicar Discussion 1
D fight ing the clutch cable General Amphicar Discussion 3
L Clutch and carb question General Amphicar Discussion 2
B SV: Re: clutch cable General Amphicar Discussion 0
T Clutch advice PLEASE General Amphicar Discussion 2
A Clutch cables, cleaning props, nut wrench size, release bearings General Amphicar Discussion 0
R Clutch in....No Clatter! General Amphicar Discussion 2
S clutch cable General Amphicar Discussion 13
E Clutch Housing Bolt Removal General Amphicar Discussion 1
D Clutch Information General Amphicar Discussion 0
B Accelerator/Clutch Problem General Amphicar Discussion 1
A CARBON CLUTCH RELEASE BEARINGS General Amphicar Discussion 1
J diaphram clutch General Amphicar Discussion 3
B Transmission and Clutch General Amphicar Discussion 0
T fix your clutch shudder - like this General Amphicar Discussion 0
B Celina tech on clutch chatter General Amphicar Discussion 0
A Clutch Judder General Amphicar Discussion 0
S In car clutch adjustment General Amphicar Discussion 1
S Clutch Adjustments (long) General Amphicar Discussion 2
T I need clutch help - PLEASE General Amphicar Discussion 6
A Hydraulic clutch? General Amphicar Discussion 1
S Clutch Adjustment? General Amphicar Discussion 0
M Clutch disk thickness General Amphicar Discussion 1
M Clutch Question General Amphicar Discussion 2
M Clutch Shudder General Amphicar Discussion 2
A clutch problem General Amphicar Discussion 3
S shift linkage/clutch cable General Amphicar Discussion 1
K Amphi clutch General Amphicar Discussion 0
A clutch trouble General Amphicar Discussion 1
D Clutch General Amphicar Discussion 18
M Clutch Problems Magnified General Amphicar Discussion 0
T Question on Gas Pedal General Amphicar Discussion 1
D Accelerator pedal - one for Hugh General Amphicar Discussion 0
A New production pedal pads now in stock General Amphicar Discussion 0
Jon March call me crazy - heres how I fixed my quarter panels General Amphicar Discussion 17
mike_israel Password reset fixed General Amphicar Discussion 0
M Hmm, have I fixed it General Amphicar Discussion 6
D Door Leaks Finally FIXED! General Amphicar Discussion 2
