checking for leaks
Arnold Hite
Brian,
I doubt water is coming in around the engine vents. I get a little
water at the front hood seal but not enough to worry about much. The best
way to tell where the water is coming from is to remove the rear seat and
watch while you put the car in the water. The leak will probably be
obvious, but even if you can't see the leak directly, you will see the
direction water is flowing from. Other club members will suggest putting a
hose in the car while on land with plug in and checking for leaks
underneath. I haven't found this as helpful but it is less trouble than
removing the seat and driving to a ramp.
Arnold Hite
Johns Island, SC
> Message: 4
> Date: Sat, 18 Aug 2001 14:58:52 EDT
> From: pfgbrian@aol.com
> Subject: Water in the bilge
> Hello, I have a freshly restored Ampi. Went in and out of the water twice,
> and a total of maybe 5 minutes swimming. Got home, and found @ 1/2 gallon
in
> the bilge at the rear. Water was below drain plug level, and below bilge
pump
> level (I used a wet vac to get out). A little dampness in the hood aea,
but
> not enough to have gone down drain tube. Could it have entered rear engine
> cover vents-I went pretty slow going in- maybe 10mph. What is normal on a
> fresh resto with new everything? Areas to check? Love our new car, but
just
> trying to learn as I can! Thanks! Brian in CA
