tommyintpa@aol.com
In a message dated 7/14/04 8:37:55 AM Eastern Daylight Time,
ahite@Charleston.Net writes:
> Is that it?
> Arnold Hite
> Still Wandering
Hi Arnold,
Where the swing arm is squeezing the end of the axle shaft. NO MOVEMENT at
all between the two. Check to see if there is a little rust around the end edge
of the axle where it is griped by the swing arm if there is it is loose. Block
the car up with the tires hanging and remove them. Jack under the swing arms
and under the drive shafts. Up and down. Grab them, shake them, make the swing
arm move on the axle if it will.
One question have you ever taken the bolt out of the swing arm?
Keep clownen around, Tommy in Tampa
> Is that it?
> Arnold Hite
> Still Wandering
Hi Arnold,
