LSolheim
Slightly less than 100 degrees today so I am a bit more active!
As I continue to chase my "Missing when hot" issue, I am now rebuilding the carburetor.
Other than a very loose injector (fishhook) o-ring the only thing I might have found is a missing ball valve (bearing) behind the acellerator pump diaphram. That is per an old Solex Manual I am using from the amphicar.com technical library. I do not see that bearing (valve) listed in the parts manual or on Gordon Imports' Parts List.
So two questions to the REAL experts:
1. Should that acellerator pump valve really exist? It looks as if it would go into the carb body's center hole (port) in the diaphram recess.
2. Is the very bottom of the "fishhook" where it inserts supposed to be slightly flattened or should it be round tubing?
Thank you,
--Larry
Thank you,
--Larry
