Carburetor Base Insulator
Tedredamphi
Where under the base of the carburetor does the 1/4" inch insulator fit in? Does it go under the baseplate or above it? Does anyone know of a source or part number for a new insulator?
Ted
CapnJohn
It goes between the carb base and the intake manifold to insulate the carb from the heat. (intake manifold/paper gasket/.25" phenolic insulator/paper gasket/carb base)
I don't have the P/N or a source for it.
tpls63
I got ont from Gordons last fall.
D Carburetor base curved? General Amphicar Discussion 2
DougFromBaltimore Carburetor Options General Amphicar Discussion 23
MAE Latest Carburetor General Amphicar Discussion 15
T Carburetor Insulator General Amphicar Discussion 0
tpls63 Solex Carburetor General Amphicar Discussion 3
LSolheim Carburetor Heat Shield General Amphicar Discussion 0
LSolheim Carburetor Rebuild General Amphicar Discussion 2
T Looking for Carburetor rebuild kit General Amphicar Discussion 10
M Carburetor, Do you need one! General Amphicar Discussion 1
E Attention - Ebay Auction Carburetor General Amphicar Discussion 0
E Dual Carburetor Balancing General Amphicar Discussion 0
E Solex Carburetor Nomenclature General Amphicar Discussion 4
S Carburetor Rebuild Kits General Amphicar Discussion 1
T the fit of the flame arrester onto the carburetor General Amphicar Discussion 2
J Sticking Carburetor General Amphicar Discussion 2
D Carburetor dripping General Amphicar Discussion 0
K Carburetor rebuilds General Amphicar Discussion 0
D Carburetor precautions General Amphicar Discussion 1
D Carburetor/ smog problems General Amphicar Discussion 1
S Base Coat Clear Coat or Acrylic Enamel General Amphicar Discussion 1
G REseat base General Amphicar Discussion 1
