Can someone post pic of Fuel shut off valve?
I have an early car that didn't originally have a magneto valve (fuel shutoff valve). Mine was mounted on the master cylinder bolt. So, to cleanup the area around the master cylinder I want to weld the bracket for the Magneto valve where it is found on later models. I think I have seen them near the heater, but if someone can post a picture of the area between the master cylinder and the heater it will be great! Hoping to weld it on tonight. Thanks!
Here is the location on this car I was working on for a friend. I didn't find Amphicar was too precise as to the exact location . I have added a steering brace on to this mount and lengthened the screw to accommodate that. I believe the original welded piece is about 1/4" thick, 1" wide and perhaps 1.3/4"inches long. Of course all the original measurements would be in mm. This is one unusual place where you don't need to be too precise on these numbers.
L Can someone tell me how to diagnose a bad relay tube? General Amphicar Discussion 2
C Someone had to speak up... General Amphicar Discussion 6
D Someone looking to hire an Amphicar.. General Amphicar Discussion 0
T Can someone bite my wife? General Amphicar Discussion 5
B First post Info on Restoration General Amphicar Discussion 8
Jon March Mike - can you read this post? ( it should be a youtube clip) - looks blank? General Amphicar Discussion 2
LSolheim Post Celina (was "Prepping for Celina") General Amphicar Discussion 5
Midwest Amphicar Why cant I post pics? General Amphicar Discussion 2
mike_israel Post a picture of your Amphicar General Amphicar Discussion 18
B Inability to post via email General Amphicar Discussion 0
Cruiserduck Looking for a 2-Post Auto Lift General Amphicar Discussion 0
mike_israel Zombie Email post Has Been Killed General Amphicar Discussion 7
A First post General Amphicar Discussion 17
A Post BJ auction positive press for Amphicars General Amphicar Discussion 7
R Post Photos General Amphicar Discussion 7
D post Celina deppresion General Amphicar Discussion 0
E Post Clipping General Amphicar Discussion 1
J Amphicar article in the St. Louis Post-Dispatch General Amphicar Discussion 1
B First post General Amphicar Discussion 1
C Post from Nathan regarding new purchase General Amphicar Discussion 0
C NY Times post General Amphicar Discussion 2
C Long time no post... General Amphicar Discussion 0
D brakes white post news letter rat General Amphicar Discussion 1
A Standing Water Tips (Re-post) General Amphicar Discussion 0
A Another Pilgrimage to Celina: (revised re-post) General Amphicar Discussion 0
A Amphi in a "Gentlemens" flick (re-post) General Amphicar Discussion 0
M White Post Restorations General Amphicar Discussion 2
M post number 2 General Amphicar Discussion 0
M White Post General Amphicar Discussion 2
R post General Amphicar Discussion 2
A Amphi Political Unity <Re-post> General Amphicar Discussion 0
