Best option is sealed beams sourced from Mainland Europe.
Amphicar use the same 7" size as Mini and Land Rover so not too difficult to find (that's assuming you can find someone who will ship to the USA with all the ongoing tariff nonsense). I always wondered why headlights on US spec cars I rented there are rubbish compared with the exact same car here in Europe. Turns out there is a ridiculous historic federal law that keeps headlights in the USA dimmer than they should be. I'll ask AI to explain, here you go:
Do car headlights in the USA still have to be dimmer than on the same model car in Europe?
Here’s the short, clear answer: Yes — U.S. headlights are still generally dimmer and less effective than European headlights, and this is due to long‑standing regulatory differences rather than technology limitations.
Below is the breakdown, grounded in the search results you triggered.
Why U.S. headlights tend to be dimmer
U.S. headlamp performance is governed by FMVSS 108, a regulation that has historically restricted beam patterns and limited forward illumination. AAA’s technical comparison notes that U.S.-compliant headlights provide less effective forward lighting, contributing to poorer nighttime visibility.
Key points:
U.S. rules emphasize reducing glare to oncoming drivers.
Beam patterns are broader but shorter.
Maximum intensity limits and beam shape requirements are more conservative.
Why European headlights are brighter
Europe uses ECE Regulation 112, which allows:
A sharper cutoff that prevents glare while still allowing a longer, brighter beam.
More advanced adaptive technologies (matrix beams, dynamic leveling) that the U.S. only recently began to allow.
EU regulations are designed to maximize visibility while controlling glare through beam shape rather than limiting brightness.
Modern LED issue: U.S. rules haven’t kept up
Autoblog reports that headlight brightness has doubled in a decade, but U.S. regulations have not been updated to properly cap or manage LED intensity. This has created a mix of:
Some lights that are too bright and cause glare.
Many lights that still don’t project as far as their European equivalents.
Bottom line
Yes — U.S. headlights are still effectively “dimmer” than European ones, not necessarily in raw lumens, but in usable forward illumination distance.
This is due to:
Different regulatory philosophies
Beam pattern restrictions
Slower adoption of adaptive technologies
