brakes that lock up!!!!
cusmacoach
After some period of driving my brakes nearly lock up. I have
adjusted the pedal travel to allow the piston to return. Any
ideas??? Very strange What causes this????
cusmacoach
--- In amphicar-lovers@yahoogroups.com, "cusmacoach" <allinapk@...>
You are in need of new brake lines. They swell inside over time and
act as a one way valve of sorts especially when hot from driving. You
can force the fluid into the cylinders, but the cylinders do not have
enough force to return it. This holds your brake shoes to the drums.
See http://www.amphicar.net/minnow/Brake_Lines.htm for some photos of
this problem.
John Bevins
Rocky Mountain Amphicar
Webmaster IAOC
this problem.
John Bevins
Webmaster IAOC
S
Scott Whaley
Before I owned an amphi I had a 64 T-bird. There is a small hole in the bottom of the master cylindar which acts as a releaf for presure for the shoes to backoff as needed when brakes are not applied. This hole isblocked by the pistonas brakes are applied. If the hole gets pluged with crud etc. brake lockup can happen. I installed all new brake system on my Amphi so waven't had this problem but I am assuming the system is the same. Scott W.
cusmacoach <allinapk@cs.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"><!-- Network content
--> <div id="ygrp-text"> After some period of driving my brakes nearly lock up. I have
</blockquote>
<hr size="1">Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2?/min or less.
S
Scott Whaley
</blockquote>
