Dave Derer
No it is a bad idea. The way you have it now does work. So do tires with
out inner tubes and no bead. The way you have it now is brake rod is
positioned only on outside edge of piston. A weak or broken brake spring
can bounce pedal and rod can fall off. By fitting rod to bore properly,
it is inserted inside and is much safer. Plus when someone else owns and
then repairs the car they wont be stuck with a short rod. Possible
suggestions that can be lethal should be deleted. Later Dave the Wave
