BRAKE PARTS for AMPHICARS
G
Gord Souter
OK FOLKS I NEED YOUR HELP.
some how over the years I have lost alot of the rear brake shoe cores.
some have not been returned(you know whom you are) others have been returned
that did not have the leaver on them.. and now that is the problem...I can
use front cores for rears but I need the levers!
and somehow I have ended up with 6 left levers and 0 rights. I talked with
Hugh Gordon and threw my mistake I got 6 more Lefts so called again but
they have No Rights to sell.
Without these levers I can not supply you guys(and galls) with my REAL
ACTUALLY STOP WHEN WET brake shoes so if you could all look threw your old
brake piles have a look for ones with levers on. I will buy them for $10.00
a piece
Gord Souter,Canadian 4 amphs,
3860 Carlyon line
RR4 ORILLIA ONT.
L3V 6H4
G
Gord Souter
a piece
3860 Carlyon line
RR4 ORILLIA ONT.
L3V 6H4
J brake master rebuild parts General Amphicar Discussion 2
A Brake hoses and My ugly divorce General Amphicar Discussion 2
W brake hose question General Amphicar Discussion 1
