Brake Drum Machine Screws
I have never before encountered brake drums that are mounted like the Amphi
drums. What is the purpose of the three small flat-head machine screws that hold
the drum to the spindle, independent of the 5 wheel studs? Maybe this is typical
of German cars?
capon23@aol.com
Ed,
I had a Porsche 914 and i remember that it had wheel studs that screwed
through the drum and into the axle rather than lugnuts...
The 3 screws insured that the drum would stay in place...
On Amphicars i think it is designed that way to make sure you don't have the
drum cocked to one side and then tighten the lugs which could lead to trouble,
also the lip on the axle in the middle that the drum sits on is not as deep
as a typical American rear axle...
Just a note--- alot of American cars with drum brakes also use clips that are
placed on the wheel studs to keep the drum in its perspective place...
John Cigarman Capone
WB6WSN
To: Amphicar List
Sent: Wednesday, January 07, 2004 2:06 AM
Subject: [amphicar-lovers] Brake Drum Machine Screws
of German cars?
Umm, replying to my own question, as I haven't seen any replies. Anybody have
any idea why our Amphi drums are designed this way?
rogtwo@aol.com
Ed,
I always thought having those brake drum screws was the norm. I was
surprised when I first saw drums without them. This is probably because I have
mostly
worked on Japanese and German cars.
Anyway, I suspect the answer to your question is simple: to some engineers
the screws seemed like a good idea, whereas to other engineers they seemed like
an unnecessary expense.
Others here have given good guesses as to why some engineers would have
chosen to use screws, but let me add one more possibility -- tradition. I would
guess that on early cars with wooden wheels (or even on horse drawn carriages),
that the brake drums had there own attachment bolts. Once this pattern of
independent bolts is established, it's hard for an engineer to say "Gee, we
don't
need any bolts to hold the brake drum on". I can just imagine the possible
logic against eliminating the bolts:
What if the wheel should fall off (not completely unheard of)? If the brake
drum doesn't have it's own bolts, then the drum could fall off too, leading to
a complete loss of brakes!
Is this a realistic concern? I doubt it, but if nobody is pushing you to
eliminate the bolts, do you want to be the engineer that suggests that the BRAKE
DRUM doesn't need to be screwed on?
Roger
White '63
Seattle
In a message dated 1/16/04 3:41:13 AM Pacific Standard Time, wb6wsn@cox.net
writes:
To: Amphicar List
hold the drum to the spindle, independent of the 5 wheel studs? Maybe this is
typical of German cars?
like the Amphi drums. What is the purpose of the three small flat-
head machine screws that hold the drum to the spindle, independent
of the 5 wheel studs? Maybe this is typical of German cars?
Ed, I meant to reply sooner! Sorry!
The 3 screws center the drums to the spindle. If you notice the
drums fit slightly loose on the studs so w/o the 3 screws the drum
will be a bit off center. This would cause uneven wear on the brake
system not to mention the surging feeling when applying them.
John Bevins
RMA
craig
RE: Re: Brake Drum Machine Screws
John, I'm going to have my drums turned soon. Do I need to make sure
they center them on those three screw holes rather then the lug stud
holes? Or is the difference not enough to matter.
Craig in Alaska
-----Original Message-----
From: a_colo_native [mailto:colo_frontrange@netzero.net]
Sent: Friday, January 16, 2004 7:57 AM
Subject: [amphicar-lovers] Re: Brake Drum Machine Screws
John Bevins
RMA
THE AMPHICAR-LOVERS LIST
This list is provided as a free service. Please support our sponsors
at:
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
<mailto:amphicar-lovers-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
sure
stud
Craig,
The best way is via the 3 scrw holes, but most equipment will not
be set up for that. Most will use the center hole, which is fine.
RMA
markr132001
Craig,
I remember having mine resurfaced. I was very insistant that they
did not cut, and cut until they thought things were right. Just have
enough taken off to make a clean surface, it is easier to cut deep
but drums are expensive. Most of what comes off is glazed surface
and just a trim is all you need. I think the 3 screws are cool and
unique. I sure was surprised to find them the first time.
Getting ready to watch the Barrett-Jackson auction this month.
Always gets the juices flowing.
Mark
--- In amphicar-lovers@yahoogroups.com, craig <alaskanamphi@g...>
sure
stud
> Craig in Alaska
> From: a_colo_native [mailto:colo_frontrange@n...]
brake
> John Bevins
> RMA
> Archives:
> visit:
at:
> amphicar770@y...
sponsors
> at:
> _____
> Yahoo! Groups Links
WB6WSN
Re: Re: Brake Drum Machine Screws
Sent: Friday, January 16, 2004 8:56 AM
John Bevins
RMA
John:
I hadn't noticed that, but that sounds like you have hit on the reason!
B SV: Brake Drum Machine Screws General Amphicar Discussion 1
E Brake Drum Performance General Amphicar Discussion 1
