azpaul50
I'm having the same problem Ed had back in 2008 with the Bilge blower. When I turn the key to "on" the blower starts running as normal. When I hit the interrupt button, not only does the blower continue running, the starter engages and keeps engaged! I changed the ignition switch with no change. Ed decided to simply bypass the timer and just use the manual blower switch. Meanwhile, I seem to recall that somebody came up with a batch of those timer tubes a while ago. I am assuming that the relays SE20/Se22 are no long available. Next step is to pull the caps off the relays and clean contacts but I think it is that tube since it never times out. Any left anywhere? - AZP
