Bildge Pump
Rusty
Can anyone tell me What is a good replacement for the original Bildge Pump,,and
where can I find it,,Thanks Russ
Sent: Tuesday, January 07, 2003 10:03 PM
Subject: [amphicar-lovers] Bildge Pump
Pump,,and where can I find it,,Thanks Russ
The Flojet 4125 is suggested. Search the Yahoo Messages area for "bilge pump";
there's a ton of info there.
W bildge blower hose routing General Amphicar Discussion 2
D Flojet bildge General Amphicar Discussion 2
J What have you found in the bildge of your car? General Amphicar Discussion 0
Latitude33 Bilge Pump outlet stainless steel tube General Amphicar Discussion 2
Jon March About the original bilge pump... General Amphicar Discussion 23
Jon March poll: original bilge pump mounting & depth gauge General Amphicar Discussion 1
okey0 Install of new bilge pump General Amphicar Discussion 3
Akamphi Bilge pump switch lamp General Amphicar Discussion 3
mike_israel Would a relay to bilge pump make sense General Amphicar Discussion 1
T Water pump General Amphicar Discussion 4
jfriese Bilge Pump Switch Lamp General Amphicar Discussion 2
C 1147 Oil pan w/ new oil pump General Amphicar Discussion 0
H amphicar bilge pump General Amphicar Discussion 7
H Bilge Pump General Amphicar Discussion 0
sdreich Water Pump Slot for Grease? General Amphicar Discussion 4
S Backup bilge pump: plumbing and wiring General Amphicar Discussion 9
G windshield washer pump General Amphicar Discussion 10
D Water pump boom General Amphicar Discussion 1
M Looking for a water pump. General Amphicar Discussion 2
L fuel pump replacement General Amphicar Discussion 2
T fule pump replacement number General Amphicar Discussion 2
S Engine Stalls - Fuel Pump Question... General Amphicar Discussion 2
C where to get a water pump General Amphicar Discussion 0
A Water Pump Noise General Amphicar Discussion 0
A Original pump alternative General Amphicar Discussion 0
T read this Original pump alternative General Amphicar Discussion 1
R Fuel Pump rebuild kit General Amphicar Discussion 1
T So you like the look of your original bilge pump... General Amphicar Discussion 2
R Water pump General Amphicar Discussion 6
D vacuum pump General Amphicar Discussion 1
M bilge pump General Amphicar Discussion 14
A This pump really SUCKS!!! General Amphicar Discussion 4
A water pump grease General Amphicar Discussion 4
A Auto Bilge Pump Without Float General Amphicar Discussion 0
J Does This Kind of Bilge Pump Exist General Amphicar Discussion 5
M fuel pump General Amphicar Discussion 16
