Big Engine
Hi Joe,
The carb is a Weber DGV 5A installed on a Pierce manifold. It also has
a fancy adapter (that looks like a flashback protector) that allows the
Amphicar air cleaner to be used and so it looks almost just like an
original installation. These systems (without the air cleaner adapter)
used to be quite common since they were used for Triumph Spitfires but
lately they have been a bit harder to locate.
What you can't see in the photo is that both my cars use the heavy duty
clutch system that I developed for Amphicars. This clutch will handle
the bigger engines and probably be a lifetime installation when running
the original engine. This clutch is easy to come by since I sell them.
Later,
Jon March Proper engine break-in General Amphicar Discussion 4
mike_israel 2-ton engine hoist for $143 General Amphicar Discussion 0
Jon March Engine compartment - !@# manual scraping. stripping, degreasing, sanding, priming, painting General Amphicar Discussion 6
P cautionary tale (my engine upgrade experience) General Amphicar Discussion 14
okey0 Engine OUT....how to mount on stand now? General Amphicar Discussion 9
Akamphi Engine oil priming tool General Amphicar Discussion 3
Ken Chambers Entertaining engine rebuild General Amphicar Discussion 0
Akamphi Spit 1500 engine break in. General Amphicar Discussion 1
AHite Possible Engine Conversion General Amphicar Discussion 8
S Pulling an engine General Amphicar Discussion 7
A engine timing and dwell General Amphicar Discussion 3
Midwest Amphicar Engines engines who needs an engine General Amphicar Discussion 4
azpaul50 Engine Cover Luggage rack General Amphicar Discussion 6
Midwest Amphicar Engine cover holes or how I spent today General Amphicar Discussion 1
B Re: Engine cooling fan General Amphicar Discussion 0
B engine cooling fan General Amphicar Discussion 2
amphicarian Engine advice General Amphicar Discussion 19
DavidC Amphicar engine in Alabama General Amphicar Discussion 0
A engine milage and mechnical status General Amphicar Discussion 7
K Engine compartment paint. General Amphicar Discussion 2
W engine and transmision General Amphicar Discussion 4
C engine rebuild General Amphicar Discussion 1
C Underside hull paint and engine compartment paint General Amphicar Discussion 6
W engine manifold mystery General Amphicar Discussion 7
B SV: SV: Re: Engine cooling / Fan noise General Amphicar Discussion 0
B SV: Re: Engine cooling / Fan noise General Amphicar Discussion 1
D engine personalities General Amphicar Discussion 1
W Engine cooling / Fan noise General Amphicar Discussion 6
B 1147 cc engine advice needed General Amphicar Discussion 2
J Harley engine ---Lake Ozarks next week General Amphicar Discussion 1
B Engine Dies When Hot General Amphicar Discussion 9
S Wankel Engine in an Amphi General Amphicar Discussion 5
S Wankel Engine General Amphicar Discussion 3
S Engine gasket sets General Amphicar Discussion 1
R rebuilt engine and tranny General Amphicar Discussion 0
