Best way to install engine/ transmission
I am almost at this point and am wondering if the engine/ transmission should go in the car bolted together, or first put the transmission in place on its mounts and then lower the engine to it :032: Thanks!
Canadian four amphs
I always put the trany in 1st, hook up all the axle shafts etc,get it on wheels, but leave propeller shafts off so you can get at bottom 2 bolts.
GORD SOUTER
CapnJohn
No question, put them in as an assembly! Get them bolted together hanging in the air to make it soooo much easier to get the trans shaft aligned and fully inserted without damage and to get the bolts properly torqued. This makes it easier by far.
Drop it in starting out almost 90 deg to final position. As you lower it, twist it slightly getting the trans under the package shelf and it goes in easy as pie. The only thing to look for is there is a small boss on the block just in front of the oil filter that can catch on the cross member. Be aware of it when you think you only have to go another 2" to go. Wrap the trans in rags to protect finish.
SNKR770
I've had my motor and transmission in and out a few times over the last few years. My preference is to do it as an assembly. The key to the whole thing is to but a $35 engine balancer. (Northern Industrial Engine Equalizer — 1250-Lb. Capacity | Hoisting Accessories | Northern Tool + Equipment)
This allows you to change the center of gravity as you lower it into the car. with three people, a towel of the transmission it glides right in. The only snafu I've encounter is to make sure you don't catch the series of wires running from the junction box on the left running across the middle to the coil, starter, etc.
millertyme Restoration question, best rotisserie, and where to mount. General Amphicar Discussion 2
T Best regard from France General Amphicar Discussion 4
JoeS 15 of the best rear-engined classics General Amphicar Discussion 0
B Best bolt-on steering brace Restorations in progress 12
SNOWBIRD 2018 Best swin in EVER! General Amphicar Discussion 3
Jon March Best spark plugs? General Amphicar Discussion 3
E Best Stripper? General Amphicar Discussion 7
jfriese Best Amphicar Article I've Seen In Years General Amphicar Discussion 1
Midwest Amphicar One of the Worlds best Amphicars at Mecum in May. General Amphicar Discussion 1
B Best Motor Oil for Amphicar General Amphicar Discussion 6
D Amphicar "the best one you will ever see" on ebay. General Amphicar Discussion 3
A Best way to tie down your Amphicar to a trailer? General Amphicar Discussion 2
K Amphi people are the best General Amphicar Discussion 3
C The best restored car? General Amphicar Discussion 9
L what is best color for resale? General Amphicar Discussion 16
D HAPPY NEW YEAR ! THE BEST DEVELOPMENT OF 2005 General Amphicar Discussion 2
R Best Amphi weekend ever General Amphicar Discussion 0
A Best Carpenter in Venice General Amphicar Discussion 1
D Back to the best part General Amphicar Discussion 0
D Best Year in review General Amphicar Discussion 0
T Best eBay desciption ever! But NOT AMPHICAR General Amphicar Discussion 2
G Double lipped seal install tips General Amphicar Discussion 0
B petronix install Restorations in progress 3
mschlem Tunnel Boot install General Amphicar Discussion 8
okey0 Install of new bilge pump General Amphicar Discussion 3
Midwest Amphicar Axle install General Amphicar Discussion 9
M Tranny Install ??? General Amphicar Discussion 3
L Low Cost Front Shock Install for Late Model Amphis General Amphicar Discussion 3
A Engine Install General Amphicar Discussion 2
M How to install a new speedometer cable...... General Amphicar Discussion 0
C Gordons Muffler install General Amphicar Discussion 5
M New door area seam seal mouldings from Hugh. How to install?? General Amphicar Discussion 4
SNOWBIRD Engine surprise General Amphicar Discussion 1
D Engine Draft Tube General Amphicar Discussion 3
Jon March Proper engine break-in General Amphicar Discussion 4
mike_israel 2-ton engine hoist for $143 General Amphicar Discussion 0
Jon March Engine compartment - !@# manual scraping. stripping, degreasing, sanding, priming, painting General Amphicar Discussion 6
P cautionary tale (my engine upgrade experience) General Amphicar Discussion 14
okey0 Engine OUT....how to mount on stand now? General Amphicar Discussion 9
Akamphi Engine oil priming tool General Amphicar Discussion 3
Ken Chambers Entertaining engine rebuild General Amphicar Discussion 0
Akamphi Spit 1500 engine break in. General Amphicar Discussion 1
