bearings, seals
K
Ken ''KD'' Roy
Here's what I'ved sucessfully used for wheel bearings & seals.
Ken Roy
04.20.03 OUTER REAR WHEEL BEARING
5206K/BCA OR 3206 DOUBLE ROLL
(30X62X23)
04.20.05 INNER REAR WHEEL BEARING SEAL
34X62X10(34X62X08) 13475 (CR)
04.20.08 INNER REAR WHEEL BEARING
(30X62X16) 206/BCA OR 6206
04.20.09 OUTER REAR WHEEL BEARING SEAL
45X62X07(45X62X08) 224530(NAT)
45X62X07(45X62X08) 17754 (CR)
05.21.20 FRONT WHEEL BEARING SEAL
68X85X10(68X85X08) CR26630
05.21.25 INNER FRONT WHEEL BEARING
TAPER ROLLER BEAR 30206 (BOWER)
05.21.26 OUTER FRONT WHEEL BEARING
TAPER ROLLER BEAR 30204 (BOWER)
Till later.....
Ken Roy
Chat with friends online, try MSN Messenger: http://messenger.msn.com
A Seals and bearings General Amphicar Discussion 0
C How to tell if thrust bearings are in place??? General Amphicar Discussion 11
G Dremil tools & bearings General Amphicar Discussion 0
B bearings and trees General Amphicar Discussion 4
A Higher prices for bearings and other parts General Amphicar Discussion 0
B Water tranny bearings General Amphicar Discussion 0
W bearings and starters General Amphicar Discussion 2
A Clutch cables, cleaning props, nut wrench size, release bearings General Amphicar Discussion 0
W Transmission bearings and gaskets General Amphicar Discussion 0
R Replacing Wheel bearings General Amphicar Discussion 3
M Rear bearings photos file General Amphicar Discussion 1
M test driving new bearings General Amphicar Discussion 0
A CARBON RELEASE BEARINGS WITH CLIPS-$30 at Amphicarparts.com/ General Amphicar Discussion 0
A CARBON CLUTCH RELEASE BEARINGS General Amphicar Discussion 1
D bearings and mistakes General Amphicar Discussion 0
D bearings and parts General Amphicar Discussion 0
G bearings General Amphicar Discussion 2
W front wheel bearings General Amphicar Discussion 3
K Rear wheel Bearings General Amphicar Discussion 0
A Brakes and Bearings General Amphicar Discussion 3
D wheel bearings General Amphicar Discussion 2
Jon March check out this clip regarding propshaft seals General Amphicar Discussion 2
H Axle oil seals. General Amphicar Discussion 2
S Master Cylinder Seals General Amphicar Discussion 3
P valve seals General Amphicar Discussion 1
G tranny seals General Amphicar Discussion 11
G door seals and vapor lock General Amphicar Discussion 0
L Transmission oil seals General Amphicar Discussion 2
W body to door seals General Amphicar Discussion 2
A Trunk seals General Amphicar Discussion 0
A Radiator Top Seals General Amphicar Discussion 2
J Pole light door seals General Amphicar Discussion 2
M rear wheel seals logic General Amphicar Discussion 2
M Rear wheel assy seals? General Amphicar Discussion 0
R Engine cover weather seals General Amphicar Discussion 0
R Replaced door seals. General Amphicar Discussion 0
R door seals General Amphicar Discussion 11
S Front Axle Oil Seals General Amphicar Discussion 2
A Transmission Seals General Amphicar Discussion 0
J Inner Door Seals General Amphicar Discussion 0
S Fuel shutoff valve seals General Amphicar Discussion 3
D sunvisor brackets rear seals General Amphicar Discussion 0
A Rear Hub Seals General Amphicar Discussion 0
J Those Rear Hub Seals (Again) General Amphicar Discussion 1
