wick68355@aol.com
Thank you for the info bearings. I have it all ready to go back together and will pick up the bearing at Napa Monday. I wanted to through out a topic for discussion on the front seal for the front hub. When I used to train auto technicians at the Chevy store I worked at, I would tell them to look at the seal and the spring in the seal. We always taught the spring went toward the fluid you wanted to keep in not the fluid you wanted to keep out. So which way does the front hubgrease seal go. I know thean swearjust thought it would be fun to hear the logic from you. Also to bench check your starter out of car, use your jumper cables and attach one lead to the smarter the other to the 12 volt lead. it should spin fast like it wasengaging in the flywheel.Timwick </font>
