--- In amphicar-lovers@yahoogroups.com, Craig Taylor
<alaskanamphi@g...> wrote:
> I have never used a blaster before. It it unrealistic to think I
could do it with my compressor?
> Craig in Alaska
I would have to say yes. A blast cabinet requires somewhere around
10-15 cfm depending on the pressure used. I have an 80 gallon tank
with 18 cfm so I dont have the compressor running all the time trying
to keep up. People usually underestimate the volume of air needed to
blast continously to do a proper job. To blast a car correctly will
need a much bigger gun than a blast cabinet uses which means a heck
of alot more cfm. CAN you do it with what you have? If you dont mind
blasting in small spurts and standing around waiting for the
compressor to catch up, yes. Can you do a job as well as a pro
blasting shop and be happy with your results, probably not. Your
blast area or pattern (area being cleaned) will also be much smaller
meaning more time behind the gun. How much time you got? More
important is do you have the proper safety equipment? For your health
& safety, you really need a full body suit and head gear to cover
EVERYTHING on your body. Pressurized dust will get into the smallest
crack you can imagine. You also would need an air line with an
outside source to breath fresh air as you dont want to breath in any
dust, paint, rust or other harmful things you will create. If you
want to clean up some parts in a cabinet I'd say have a blast (pun
intended)and go do it. For the $600-800 a shop might charge I'd let
the pros do the car itself. Just my opinion.
