Bead Blasting an Amphi
Craig Taylor
I'm in the market for a bead blast system to do my Amphi with. I have a 6hp
compressor that puts out 6.5 CFM @ 90 psi. Anyone out there recommend a blast
system that could do the job?. I plan on using plastic around the car to contain
the blast media.
Craig in Alaska
Red 66 Amphicar(RDUCKY)
--- In amphicar-lovers@yahoogroups.com, Craig Taylor
have a 6hp compressor that puts out 6.5 CFM @ 90 psi. Anyone out
there recommend a blast system that could do the job?. I plan on
using plastic around the car to contain the blast media.
> Craig in Alaska
At least you have those endless nights up there. You'll need them to
blast a car with only 6.5 cfm.
Craig Taylor
Re: Re: Bead Blasting an Amphi
I have never used a blaster before. It it unrealistic to think I could do it
with my compressor?
Craig in Alaska
could do it with my compressor?
> Craig in Alaska
I would have to say yes. A blast cabinet requires somewhere around
10-15 cfm depending on the pressure used. I have an 80 gallon tank
with 18 cfm so I dont have the compressor running all the time trying
to keep up. People usually underestimate the volume of air needed to
blast continously to do a proper job. To blast a car correctly will
need a much bigger gun than a blast cabinet uses which means a heck
of alot more cfm. CAN you do it with what you have? If you dont mind
blasting in small spurts and standing around waiting for the
compressor to catch up, yes. Can you do a job as well as a pro
blasting shop and be happy with your results, probably not. Your
blast area or pattern (area being cleaned) will also be much smaller
meaning more time behind the gun. How much time you got? More
important is do you have the proper safety equipment? For your health
& safety, you really need a full body suit and head gear to cover
EVERYTHING on your body. Pressurized dust will get into the smallest
crack you can imagine. You also would need an air line with an
outside source to breath fresh air as you dont want to breath in any
dust, paint, rust or other harmful things you will create. If you
want to clean up some parts in a cabinet I'd say have a blast (pun
intended)and go do it. For the $600-800 a shop might charge I'd let
the pros do the car itself. Just my opinion.
V
vaircrazy
> Craig in Alaska
Craig,
You can do it if you double the size of your tank or more, it is
volume and lots of it. My blaster I built holds a 100 pound bag of
sand or bead material. I use a 1/8 inch nozzle and can only blast 15
minutes and break for 15 to let the compressor cool(it runs
continuous) and I have two upright tanks about 140 gals. Now with
glass bead you might get away with a smaller tip which would allow a
lot less air. Remember to cover everything in the room you will find
blast material in places you would not expect it.
Mike Bayman
Urbana,Ohio
Craig Taylor
Thanks John... I have the time. I work two weeks on and two weeks off on the
pipeline here in Alaska. So I'm tempted to try it. If for nothing else I could
do the rusty areas and leave the rest for a shop. Thanks for the advise.
Craig in Alaska
Bill Connelly
blast system that could do the job?. I plan on using plastic around the car
Craig in Alaska
I'd suggest asking either Billy Syx of East Coast Amphicar (see
www.amphicar.net/eca for telephonic contact info) or Dave the Wave at
Midwest Amphicar www.midwestamphicar.com for their reccomendations.
~Bilgey~
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.558 / Virus Database: 350 - Release Date: 1/2/04
D Bead roller General Amphicar Discussion 0
K "Starter" Bead Blast Cabinet General Amphicar Discussion 0
P Soda Blasting General Amphicar Discussion 6
C Soda blasting... General Amphicar Discussion 5
R Fwd: Re: Soda Blasting (rag-jag)!!! General Amphicar Discussion 1
C Soda Blasting General Amphicar Discussion 4
B Water Blasting General Amphicar Discussion 4
D media sand blasting Mt Dora project Amphi General Amphicar Discussion 0
mike_israel Another amphi on Bring a Trailer General Amphicar Discussion 3
Mark Richardson Amphi Owners Club Newsletter General Amphicar Discussion 5
RalphF Georgia Amphi Restoration Restorations in progress 15
RalphF Amphi Shirt General Amphicar Discussion 4
mike_israel Amphi article in Classic Motorsports Magazine General Amphicar Discussion 0
mike_israel The Time Has Come ... Selling the Amphi General Amphicar Discussion 7
SNOWBIRD 1965 Amphi project General Amphicar Discussion 1
Jon March Insurance when towing Amphi vs when on road? General Amphicar Discussion 5
Jon March Suddenly "revving up" when in water -Does your Amphi do this? General Amphicar Discussion 12
Jon March Anyone know who ended up buying this Amphi? General Amphicar Discussion 1
SNOWBIRD 64 Amphi??? General Amphicar Discussion 0
mike_israel OT: Something like this could be useful for Amphi and parts purchases General Amphicar Discussion 0
SNOWBIRD Amphi bottoms General Amphicar Discussion 1
Jon March we could all use help with this Amphi issue: General Amphicar Discussion 0
mike_israel Amphi on Bring a Trailer General Amphicar Discussion 2
mike_israel What did you do to your Amphi today? General Amphicar Discussion 16
Bilgemaster Original Amphi Key No. 5415? General Amphicar Discussion 13
Mark Richardson RHD Museum Amphi sells at BJ auction this weekend..... General Amphicar Discussion 2
Mark Richardson 2017 Barrett-Jackson auction includes single Amphi General Amphicar Discussion 7
Cameron in UK Anyone know the source of this New York Amphi photo ? General Amphicar Discussion 6
dutchamphi Amphi-scooter General Amphicar Discussion 1
SNOWBIRD A blip on Fred's Amphi. General Amphicar Discussion 0
mike_israel Future Amphi Owner Earns Eagle Scout General Amphicar Discussion 3
mike_israel Toolbox Deal at Home Depot (No Amphi Content) General Amphicar Discussion 0
Mark Richardson Amphi sold at Barrett Jackson tonight General Amphicar Discussion 0
mike_israel Securing Amphi and Trailer General Amphicar Discussion 7
mike_israel Non-Amphi garage project - shelves General Amphicar Discussion 4
amphi-Ben Amphi Swim In the Netherlands General Amphicar Discussion 3
mike_israel It's the Amphi-Jeep for Less than $2k General Amphicar Discussion 1
azpaul50 Amphi with Spare Harley behind! General Amphicar Discussion 0
SNOWBIRD Another Amphi swims General Amphicar Discussion 0
A Barn Find 1965 Amphi Restorations in progress 3
Midwest Amphicar Why you should visit Florida with your Amphi General Amphicar Discussion 1
Midwest Amphicar Amphi fins and snow drifts General Amphicar Discussion 4
Mark Richardson Barrett-Jackson Auction Amphi General Amphicar Discussion 2
Midwest Amphicar Another sweet Ebay Amphi General Amphicar Discussion 0
Midwest Amphicar Sweet Ebay Amphi General Amphicar Discussion 2
azpaul50 Amphi at Auction General Amphicar Discussion 0
azpaul50 Home-made Amphi in Calexico, CA General Amphicar Discussion 2
