Axle tube bushings - a followup question...
Jon March
I cant find the thread, but a while back, when describing the method for assembling the rear swing arm/axle tube/axle nuts/tension, etc, Cameron Chapman was kind enough to mention the following:
before assembling - check the (outer) brass bushing where the weight rides in the outer round axle tube housing - that can wear - and a 1/6 turn from its original 12' oclock position, to a fresh, unworn area of the tube, can give more life
My question - why 1/6th in particular? I would agree that 180 degrees might have some upward-wear, but would maybe 2/6ths of a turn be the freshest area? That said - I expect that a visual inspection of the original 12'oclock postions would best inform as to the cleanest area to call the "new" 12'oclock position!
E Axle Tube Greasing General Amphicar Discussion 0
LSolheim Axle Weights General Amphicar Discussion 3
Jacques B. Amphicar Axle shaft removal from the gearbox General Amphicar Discussion 5
cigarman Axle Tunnel repair (welded in wrong) General Amphicar Discussion 4
H Axle oil seals. General Amphicar Discussion 2
Midwest Amphicar getting ready for some axle suck in Sabula General Amphicar Discussion 0
T Axle Zerk Fitting??? General Amphicar Discussion 3
T Axle u-joints General Amphicar Discussion 3
Midwest Amphicar Axle install General Amphicar Discussion 9
C RUBBER AXLE CAPS !!! General Amphicar Discussion 24
J AXLE CAPS !!! General Amphicar Discussion 0
D axle suck soon very soon General Amphicar Discussion 0
A Axle tunnel repair General Amphicar Discussion 0
B Rear Swing Axle Needed General Amphicar Discussion 1
R double axle trailer General Amphicar Discussion 1
T Shocks, axle boots General Amphicar Discussion 1
G Axle question General Amphicar Discussion 9
G rear axle. General Amphicar Discussion 1
C Rear Axle rebuilding General Amphicar Discussion 1
A REMOVING AXLE HOUSING WITH AXLE General Amphicar Discussion 1
K Axle sliipiing out of tranny General Amphicar Discussion 0
D axle- river General Amphicar Discussion 0
D help with axle idea ---- Great book General Amphicar Discussion 2
C Axle shaft removal General Amphicar Discussion 4
C rear axle boot General Amphicar Discussion 4
E Rear Axle Spline Compression Springs General Amphicar Discussion 2
E Axle Nut & Washer Sequence General Amphicar Discussion 0
E Axle Nut Torque General Amphicar Discussion 0
D Rear Axle Tunnel To Tranny Boots General Amphicar Discussion 3
W TIP; Split axle reassembly. General Amphicar Discussion 0
E Rear Axle Design General Amphicar Discussion 1
R single axle General Amphicar Discussion 0
R Axle success General Amphicar Discussion 0
A trouble with axle General Amphicar Discussion 0
S Front Axle Oil Seals General Amphicar Discussion 2
